Thread: creaking interior
    Jul 2009
    county durham
    Default creaking interior
    ive got a serious creaking coming from the rear pasenger side just above the rear door,its one of those noises what does ya head in,any ideas what it could be or does anyone else have the same creaking sound,cars a vectra c sri on a 02 plate??cheers
    Regular Member KSD's Avatar
    Aug 2007
    Cupar, Fife
    The rear window may be drooping slightly, is it more prominant on uneven ground?
    Jul 2009
    county durham
    Quote Originally Posted by KSD View Post
    yeah mate,on the motorway its fine but soon as you hit unevan ground it starts creaking quite bad
    Aug 2007
    Cupar, Fife
    Quote Originally Posted by lowsri View Post
    Wind the rear window down a little and apply slight pressure to the top of the window glass as if you were pushing it open, if it moves in a downward direction slightly then it is loose and requires tightening somehow.
    Jul 2009
    county durham
    ive had a look at the window its fine,ive drove down a bumpy road with the boot and rear door open and it sounds like its coming from the headliny area,im stumped,thinking of dropping the headlining to have a look.
    wirral,merseyside
    isnt there a how 2 on here for droping the headlining+re riviting something??
    sure some one will clear that up for you mate
    Jul 2009
    county durham
    Quote Originally Posted by cooki View Post
    anyone no about this,could be a big help?
    Check out the 'How2' it's your friend this may help http://www.vectra-c.com/forum/showthread.php?t=24043 .....................
    Regular Member Largespanners's Avatar
    Jul 2009
    Swindon
    I had a similar problem, found the door had dropped slightly on it's hinges.
    I adjusted the door lock plate (on the car body) and that sorted it. Might be something similar?
    Aug 2009
    north east
    I had a problem with the tailgate on mine, the lock was rattling and squeaking. I adjusted the two bump stops on the tailgate corners which sorted it. It did sound like it was from the headlining however. Took an age to find it.
  1. creaking
    By marc vectra sri in forum Bodywork & Interior
    Last Post: 25th August 2011, 08:13
  2. creaking noise
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2008, 15:00
  3. Creaking
    By Sean-2.2Direct in forum Suspension, Wheels & Brakes
    Last Post: 26th November 2008, 18:12
  4. creaking seats@@@ =O
    By daveondanet in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2007, 16:08
  5. creaking noise
    By johnnyhg in forum Vectra C / Signum Car Chat
    Last Post: 30th June 2006, 19:52
