Thread: Engine Fault?? Need Help Please !!!
    Aug 2009
    PERTHSHIRE
    Default Engine Fault?? Need Help Please !!!
    Hi i just got a Vectra 1.9CDTI 120 estate ( 06 reg) and having a wee problem with it and was hoping someone could point me in correct direction as to a diagnosis or repair.
    I will try to describe symptoms as best i can. and bear in mind i am a vehicle engineer ( not cars!!).
    it is an intermitten fault.
    it happens mainly when i have changed to second gear and accelerating up.
    usually revs is reading between 2000 and 3000 rpm.
    rev counter seems to stay steady.
    is like car has "kangaroo fuel", i e stuttering, burping etc. but not serious enough to cause rev drop or engine warning light etc.
    is a strange fault and doesnt always do it
    i had window open today and it sounded like something going off and on then staying on when running ok again
    hope this helps????
    ian
    Jul 2009
    sussex
    egr valve needing a clean perhaps?
    lanark
    5 Post(s)
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    that was my thought also especialy if it's not been done before
    Aug 2009
    PERTHSHIRE
    Default egr valve
    how do i clean valve?? is there a how on here??? and do i need to order parts before i do it??
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    no parts required bud remove unit (4 bolts, 2 nuts, braket,)clean inside body ,clean plunger and housing,i use brake cleaner Theres allsorts of cleaners available) and a small brass wire brush ,just be patient and keep at it,when its clean refit is reverse
  1. engine fault please help
    By neill in forum Engine & Drivetrain
    Last Post: 7th August 2011, 06:28
  2. 2.0 dti engine fault
    By huddsy in forum Engine & Drivetrain
    Last Post: 8th April 2011, 21:36
  3. Engine fault ???????????????????
    By tony24 in forum Engine & Drivetrain
    Last Post: 21st April 2009, 18:11
  4. Engine Fault Code
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2008, 18:34
  5. Engine Fault
    By bentleyboy in forum Engine & Drivetrain
    Last Post: 13th December 2005, 22:08
