Results 1 to 10 of 13
Thread: help parking sensors
    Slough
    92 Post(s)
    Vehicle : insignia vxr
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    Default help parking sensors
    hi all bought a parking sensor kit off don paul at billing then got a sri bumper of other member thanks john which had the cut outs for the sensors the problem is the hole is to big for my sensors .what i need to know can i buy some vauxhall sensors and will they be compatible with the kit i got luckly it is only the rear bumper as when i do the front i will drill the holes with the bit with the kit .
    WGAF#5
    not sure if the vx ones will be compatible with someone elses kit?
    what make's the one from Don Paul??
    amazed that parking sensor holes are a different size dependant on manufacturer
    Slough
    92 Post(s)
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    they are gagetman kit and the hole size is 21mm if that helps
    Full Member Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Im pretty sure the hole for genuine factory fitted sensors is 21mm aswell, But VX do a kit that takes the same genuine sensor but the brackets require a 29mm hole for the sensor to fit in.. Not sure if VX ones will work with another kit though..
    You might be able to use the larger 29mm brackets for your sensors, they weren't very expensive from the dealers..
    WGAF#5
    what size is the hole in the bumper??
    Slough
    92 Post(s)
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    thanks for the info guys hopefully the guy at the body shop will be able to sort it out for me just waiting on a boot spoiler then it will go to get sprayed then just need a twin exhaust
    just been out and they are 30mm
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by Big-Pete View Post
    I ordered some for my parkpilot kit today, they are £14
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Engine : 3.0 TDV6
    Mileage : 3023
    I knew they were fairly cheap, as LMF ordered the bigger ones by mistake for me and they replaced them with the 21mm factory ones as thats what i needed, and told me to keep the others as it wasn't worth sending them back, i still have them somewhere..
    Slough
    92 Post(s)
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    big pete would take them if you think they will fit the wireing on the aftermarket ones i have
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Engine : 3.0 TDV6
    Mileage : 3023
    Yeah sure m8, i'll have a look for them in the morning after my gym visit.. They are still here im sure of it..
  1. OE Parking sensors
    By Dippy-Vx-line Red in forum Electrical & ICE (including SatNav)
    Last Post: 19th January 2012, 19:02
  2. parking sensors
    By happypostie in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2009, 02:04
  3. HELP parking sensors
    By lee11 in forum Vectra C / Signum Troubleshooting
    Last Post: 4th December 2009, 13:38
  4. Parking Sensors! Help!
    By Schui1024 in forum Electrical & ICE (including SatNav)
    Last Post: 5th October 2009, 23:52
  5. Parking Sensors
    By Mick B in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 21:58
