Thread: Help required ASAP!
    Regular Member Matt21385's Avatar
    Ayrshire Scotland
    Trim : VXR
    Engine : 2.8 V6
    Default Help required ASAP!
    When removing front suspension does the sping have to be compresed before removal from the car or is this done when the shocker & spring are romoved as a unit?
    cheers
    Regular Member Ian's Avatar
    York
    With Macpherson struts the whole unit should come off the car as one, then compress the spring and then undo the top nut. Would think the vec the same as all the others I have done?
    Ayrshire Scotland
    Trim : VXR
    Engine : 2.8 V6
    Quote Originally Posted by Ian
    Thanks for that Ian, was thinking that myself but just wanted to check. Fitting my Koni FSD shocks today
    Just like Ian say's..
    remove strut assy and compress spring when it's off the car..
    Regular Member Spikeyİ's Avatar
    Dec 2005
    In the sponge-monkey tent
    Quote Originally Posted by Matt21385
    You'll love them mate, what springs are you using with them?
    Ayrshire Scotland
    Trim : VXR
    Engine : 2.8 V6
    Thats them all fitted, just on the standard SRi springs the now Spikey. Was meant to get Koni springs but was a problem with the order, so will get them at a later date.
    Dec 2005
    So how low does it sit? What's the ride like? Does it go round corners like it's on rails?
    Ayrshire Scotland
    Trim : VXR
    Engine : 2.8 V6
    Quote Originally Posted by Spikeyİ
    Its sitting about the same as before because its the same springs. Will change them soon, probably get Koni springs. Not had the chance to take it out for a spin yet
    Dec 2005
    Been out in it yet?
  1. cdti whistle help required ASAP
    By raddish in forum Vectra C / Signum Car Chat
    Last Post: 27th March 2010, 14:08
  2. vec c mirror required asap!!!!
    By kojak01 in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2008, 22:16
  3. Suspension help required ASAP
    By Gregg in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2007, 19:30
  4. Oi filter help required ASAP!
    By Matt21385 in forum Engine & Drivetrain
    Last Post: 3rd April 2007, 15:44
  5. Help required asap with wing mirrors
    By Matt21385 in forum Styling
    Last Post: 29th May 2006, 23:09
