Thread: Light coloured smoke from engine
    Regular Member beethamwest's Avatar
    Jul 2009
    Liverpool
    Default Light coloured smoke from engine
    Was on the M57 motorway heading towards Maghull (heading from Halewood) and my oil levels low light came on. So i turned around at Switch Island and headed home (about 14 miles from noticing the light, to arriving back home)
    Cheked oil levels, and they were low so filled it up with 1/3 of a bottle that i had left from a previous car
    HOWEVER upon refilling, i noticed down from where you pour the oil in, a still wet liquid was present, as if i have a leak? it was wet so i am assuming a leak of oil.
    Not only this, but when i started the engine to see if the oil was indeed exiting from somehwere, a constand but very light and steady amount of smoke was coming from further down in the engine. I don't know whether this is the leaked fluid in contact with hot parts just making smoke, of if something serious is wrong. Engine sounds fine and no warning lights. I would not notice the smoke if the bonnet is shut
    Its an 03 1.8 LS 16v with 110,000 on the clock
    VOTING UKIP IN AVELEY
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    if your oil level was that low it might mean you have a small leak somewhere ,and it would as you stated be the reason for the light smoking ....has there not been a tell tell sign under the car when parked up ??????
    Jul 2009
    Liverpool
    double post
    Jul 2009
    Liverpool
    treble post
    Jul 2009
    Liverpool
    I have not been aware of anything on the floor, however i do see a 1inch x 1inch drop stain on the floor, however this could have been from when i poured the new stuff in before
    Just been out to take some foto's, the area of engine covered by oil has increased, therefore the only conclusion is a leak
    Here are two fotos'
    You can see the area stained (darker than normal) and you can see the small drop on the floor
    This entire area is stained by oil
    Jul 2009
    Liverpool
  1. Help smoke from engine
    By Sway in forum Engine & Drivetrain
    Last Post: 27th January 2013, 18:46
  2. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  3. Smoke from engine
    By elite_150 in forum Engine & Drivetrain
    Last Post: 7th December 2012, 22:26
  4. Smoke in my engine bay - oh no!
    By steve533 in forum Engine & Drivetrain
    Last Post: 15th January 2012, 14:48
  5. Smoke From My Engine
    By Keith01 in forum Engine & Drivetrain
    Last Post: 10th March 2011, 23:01
