Results 1 to 2 of 2
Thread: Y30DT EGR Valve
    Regular Member r.bailey63's Avatar
    Mar 2007
    Stockton on Tees
    Default Y30DT EGR Valve
    Today I have replaced my EGR Valve after removing it a couple of weeks ago for cleaning, then having to wait 2 weeks for a pair of new inlet manifold gaskets from the dealer. Having reassembled everything I started it up and at first it seemed exactly the same as before I cleaned the EGR valve, so went for a test drive, got about 200 yards and got the yellow spanner and limp home mode, so I limped it back to the drive, left it switched off for 10 mins then tried it again, now I just have the emissions light on the dash and it doesn’t want to seem to rev.
    Anyone have any ideas?
    Thanks.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    You either damaged the EGR or not connected the plug on top of it, or there is a boost leak(can't remember if the EGR is operated by vacuum like on the 2.2).
    Mine did the exact same thing as yours. Spanner light first then emission light after restarted with the fault stil present.
  1. Why why why y30dt.....
    By martyngell in forum Y & Z30DT Specific
    Last Post: 31st May 2012, 14:04
  2. y30dt egr
    By phil0464 in forum Vectra C / Signum Car Chat
    Last Post: 18th July 2011, 08:43
  3. Y30DT - Turbo Cover - easiest way to block EGR valve
    By pembuk in forum Engine & Drivetrain
    Last Post: 27th June 2011, 13:02
  4. how 2 on cleaning egr valve 3.0 v6 cgti y30dt
    By signum03 in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2009, 19:32
