Thread: Are my lights needing re-aimed
    Regular Member 19CDTi's Avatar
    Jul 2009
    Perth, Scotland
    Default Are my lights needing re-aimed
    Had the new Vec out at night last time, the dipped lights seem to be really far down, even at "0" on the adjuster... do they need realigned or are all facelift Vec Cs like that??
    Stuart
    Regular Member m3ath3ad's Avatar
    Aug 2007
    Minehead
    im guessing they probly need re-aiming m8, any where whith an mot bay will do it
    Jul 2009
    Perth, Scotland
    Quote Originally Posted by m3ath3ad View Post
    Cheers, How much am i looking at mate?
    lanark
    5 Post(s)
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    they might be ok for allingment as vec dipped beam are very bad as standard
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    Quote Originally Posted by 19CDTi View Post
    Stuart
    I thought mine was quite low too when I had my vec-c. (seems common occurance) It's quite a easy matter to raise them slightly.
    Duncan did a useful How-2 for adjusting them and is in the How-2 section of the site.
    Basically, the easiest way is to position your car in front of a wall or garage door, and put your beam position switch in its highest position.
    Then put a mark where the lights hit the wall using a bit of tape or whatever.
    Then lower your beam height switch down to the centre, ie a couple of notches. Then using a Allen Key you can adjust the lights back up to the position they were originally. The lamp height adjustment is dead easy, and is done by inserting the Alen key in the holes along the top of the front grill, ie. across the top where the bonnet lock is. There is two either side, the outside two are the dipped.
    Unfortunately I dont remember the Alen key size.
    If you have them done at the dealers, make sure you set your beam position switch to the centre or one notch lower before taking it in. That way it will give you a little room to raise it more afterwards if you feel it needs it. IME most dealers tend to set them a touch low instead of a touch high to be on legal safe side.
  1. Help needing urgently!!!
    By Stevie_VXR in forum Vectra C / Signum Car Chat
    Last Post: 20th July 2012, 16:15
  2. noob needing help!
    By bonus in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd February 2010, 21:32
  3. Do I have A Problem Needing Looking Into?
    By Ben H in forum Suspension, Wheels & Brakes
    Last Post: 3rd August 2008, 23:40
  4. Anyone needing parts!
    By bruceybonus in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2008, 19:27
  5. Needing Pads Already
    By dave16v in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2007, 18:08
