Results 1 to 3 of 3
Thread: 1.8 vvti grumbling sound
    Regular Member videodoctor's Avatar
    Blackpool
    Default 1.8 vvti grumbling sound
    I have a 07 facelift 1.8 vvti exclusiv Vectra and for a while now it grumbles on heavy acceleration.
    If i come to a junction where i don't have to stop and change down into 2nd to carry on the car seems to make a grumbling sound until the revs are higher.
    It sounds to me like either the exhaust is blowing slightly or could it be if the garage haven't used the correct grade of oil?.
    The car in general runs fine with full acceleration but this grumble has just started in the past few thousand miles.The car only has 13,000 on the clock.
    Does anyone elses 1.8 vvi make this sound?
    Thanks alot for any help.
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    Quote Originally Posted by videodoctor View Post
    Have had similar noises from my 1.8vvt Insignia.
    I think what your hearing is resonance noises coming back through the bulkhead. Check under the bonnet for anything that may be causing a vibration noise at certain rpm. On the Insignia 1.8 models the airbox has been causing lots of resonance issues for people, quite loud too around the 2k-3k rpm mark. A couple of small pieces of foam placed under the airbox seems to fix it on the Insignia, in fact its now a VX field remedy fix..lol
    It will likely be something silly and simple to fix, but the noise can be very annoying. AIS check that airbox area first, mine is rubber mounted as your will be, but it still made a noise at certain rpm, a bit of foam underneath solved it.
    Wierd noises can often be awkward to locate, and in your case it could be many things, from something under the engine vibrating or resonating to even the exhaust which may be catching the body due to a broken/bad exhaust mount. Hope you sort it.
    Alternatively as a last resort, a visit to the dealer may be justified, and get them to sort it out under the warranty.
    Blackpool
    Thanks for the reply Cameron43.I hadn't thought of things vibrating so i'll have a look this afternoon.
    Cheers for replying so fast
  1. What is meant by 1.8 VVTI? is the vvti engine better or worse?
    By Deann in forum Vectra C / Signum Car Chat
    Last Post: 14th May 2011, 11:19
  2. Front brakes grumbling
    By ali06 in forum Suspension, Wheels & Brakes
    Last Post: 29th May 2010, 20:31
  3. 1.8 VVTi LPG
    By ShauneDTi in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2010, 11:30
  4. Vectra 2.2dti "grumbling/knocking" noise
    By Peetoki in forum Engine & Drivetrain
    Last Post: 17th February 2008, 14:51
  5. 1.8 vvti or not
    By surreyl31 in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2007, 23:30
resonate from exhaust system vectra c vvti site:www.vectra-c.com
resonate noise from under bonnet of vectra c vvti
resonance sound from front of vectra c vvti 1.8
