Results 1 to 10 of 14
Thread: tyre pressure.......?
    Regular Member david.aka.judas's Avatar
    Suffolk
    Default tyre pressure.......?
    can some one let me know what tyre pressure I need to run at for a 225/40/18 please?
    I was thinking of 34 is that okay?
    Regular Member sparky71a's Avatar
    Apr 2006
    At the Garage
    Yep should be fine,dependent on if your carrying weight,or doing a long drive.
    I usually run at 35 front and if loaded for travel 36 rear on 225/45/r17.
    Rule of thumb is twice the rim size plus 1 or 2 psi. That sive should be in the handbook but tbh I would put at least 36-38 and i would keep an eye out for the tyre wear
    Regular Member fuzzbomUK's Avatar
    Milton Keynes
    I have a GSI and the owner manual states 40psi front and rear.. 215/50/17
    I thought that was a tad high. any thoughts?
    lanark
    6 Post(s)
    Year : 2017
    Quote Originally Posted by fuzzbomUK View Post
    i would be running those at about 36psi
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Yep the heavy V6's have high pressures.
    Suffolk
    heavy engines - they must know something they designed it...lol
    spoons
    Guest
    On the VXR its 42 psi front and 38 psi rears (235/40/18)
    Suffolk
    Quote Originally Posted by spoons View Post
    so - if I'm running the same size tyres on aftermarket alloys.... is 34psi too low then on a 2.2i direct?
    cheers.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    I run 36-38 on my 2.2 mate on 17's. Think the pressures are the same for 17's and 18's. The big jump comes at 19's. I tend to run softer on the rear to keep it a bit more docile.
  1. Tyre Pressure?
    By Knuckle in forum Suspension, Wheels & Brakes
    Last Post: 31st May 2011, 07:21
  2. what tyre pressure??????
    By dannyjpuk in forum General Chat
    Last Post: 6th March 2010, 21:27
  3. tyre pressure
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2009, 10:30
  4. tyre pressure for GSI
    By effone in forum Handling & Braking
    Last Post: 7th December 2008, 06:07
  5. Tyre pressure
    By EARLEY in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2007, 18:41
