Results 1 to 10 of 16
Thread: ALLOY WHEELS. HOW TIGHT ARE YOURS.? Do You Think 150nm is too tight.
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    Default ALLOY WHEELS. HOW TIGHT ARE YOURS.? Do You Think 150nm is too tight.
    I checked the wheel nuts on my 18" Alloys on my Insignia yesterday, and they did not appear very tight at all.
    On checking with the Torque wrench they seemed to be tightened to around the 80nm-85nm mark, with several much less than that.
    The Insignia uses large 22mm wheel nuts, and the manual states for alloy wheels that they should be tightened to 150nm.
    Does that sound rather high to you. My vec-c (steel structure) wheels used to be 110nm, which seems more reasonable.
    Not been able to find any specific info on-line, other than what it states in the manual ie. 150nm.
    Would you risk it, and torque them up to this. 150nm is pretty high, and am worried it may cause damage to the wheels if I do so.
    What do you guys think?
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    The torque setting on my S60 is 140nm. This is also with 22mm wheel nuts, so I think it sounds about right.
    Apr 2008
    In UK
    Quote Originally Posted by pricey View Post
    I assume the above is on Alloys too?
    Will set mine to 140nm too I think, certainly way tighter than what they are currently, almost half that at the moment.
    Thanks matey... I just did'nt want to risk causing damage, and 150nm sounded a lot to me... lol
    Regular Member AdeyCorp's Avatar
    Chesterfield
    If the manual say 150nm then it cant be wrong. As if it cause damage, you have it in writing to take any damage back to the dealer.
    Quote Originally Posted by Cameron43 View Post
    Sorry, yes it's on 17'' Alloys.
    I was surprised it was so high after being used to 110nm on the Vectra but I assumed it was due to the larger wheel nuts.
    Apr 2008
    In UK
    Quote Originally Posted by AdeyCorp View Post
    The Insignia manual is not renowned for its accuracy, at least not on some things... lol
    However, you have a very good point, but think I'll just do them up to 140nm to be on safe side. (Thats still pretty tight.)
    Apr 2008
    In UK
    Thats exactly my thoughts too, the 22mm nut size will definately take it, it was the poor wheel I was thinking off....lol
    Your post has allayed any worries I was having, and will set mine the same..
    Many thanks again.
    Ashington, Northumberland
    150nm isn't that tight at all really, but that is the sort of torque for that size of wheel nut/bolt I would expect.
    Apr 2008
    In UK
    Quote Originally Posted by GARY3306 View Post
    Well I ended up doing all the wheel nuts up to about 140nm, which is what they use on the Saab S60 alloys and same 22mm nuts, so should be okay I think.
    I was a bit surprised to find at least 4 nuts which were very loose indeed, in fact the weight of the toque wrench on its own was sufficient to turn the nuts.. not good. So its obvious the dealers dont check them very often, if at all, when the cars go in.
    You really are better off putting them up to what the manufacturer states they should be. Trust me, they won't snap or strip
  1. How tight are you?
    By signum_rob in forum General Chat
    Last Post: 14th May 2012, 21:48
  2. Tight Van Man
    By Big Dave in forum General Chat
    Last Post: 16th June 2011, 11:07
  3. Why is Vx so tight?
    By lencuff in forum Electrical & ICE (including SatNav)
    Last Post: 13th January 2011, 03:37
  4. help tight steering
    By scotspie501 in forum Engine & Drivetrain
    Last Post: 23rd January 2010, 21:21
  5. hee hee im a tight wad!
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2006, 21:57
