Results 1 to 10 of 11
Thread: Does the design have sports or standard shocks
    Regular Member parky's Avatar
    washington
    Default Does the design have sports or standard shocks
    Hi I have a design 1.9d (150) will it have standard shocks or sport I need to replace one at the front but one garage said standard and another said it sports shocks.
    Should I replace the leaking one or both?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Don't know if its sports or not but you should always replace these things in pairs. The other one will probably go the same way anyway so just as well to sort it now
    Regular Member signumboy's Avatar
    Edinburgh/outskirts
    Engine : 2.0 Ltr Turbo
    Mileage : 38000
    Design has same set up as SRI so i am guessing Sports
    washington
    Thanks for the replies
    11 Post(s)
    Quote Originally Posted by signumboy View Post
    I thought the Design was built for comfort, and thus wouldn't have thought it had sports suspension.
    OP, if you goto your Vaux dealer with the car's chassis number, they should be able to tell you one way or the other.
    Regular Member PORKBALLS29's Avatar
    Epping
    The design has the sports shocks they are 15mm lower than the standard ones. HTH
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    I have an 05 design Vectra and it does not come with sports suspension as I have added SRI shocks and springs and it is now 15mm lower than standard, the signum is different as I recall.
    Edinburgh/outskirts
    Mileage : 38000
    Signum Design has same kit as SRI . IE 15mm lower than standard .trust me i have one
    26 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Yes my point PARKY has an 04 Vectra which doesn't have the sports suspension on the Design as I said I thought the Signum was different.
    washington
    Hi Paulhb has fitting sport suspension improved the ride of the car
  1. Broken springs - do you have standard or sports versions...
    By MrT in forum Suspension, Wheels & Brakes
    Last Post: 24th January 2013, 10:59
  2. sports shocks
    By tazdog03 in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2012, 20:07
  3. Uprated Sports Suspention (Rear Shocks)
    By scottymf in forum Suspension, Wheels & Brakes
    Last Post: 15th July 2010, 22:27
  4. Design Spring and Shocks
    By Matt&Jemz in forum Parts for sale
    Last Post: 5th April 2010, 11:34
  5. Rear Shocks for Signum CDTI 3.0 Design
    By Oily Rag in forum Suspension, Wheels & Brakes
    Last Post: 14th June 2008, 21:48
