Thread: Heat rear window
    Regular Member Paul 360's Avatar
    Jan 2006
    Billinge
    Default Heat rear window
    Hi can any body help ,the heated rear window dose not come on but the door mirrors do any ideas please
    I believe they are under different fuses. The rear window fuse should be number 4 in your boot fuse box (40A job). I'd have a look here first.
    Jan 2006
    Billinge
    Thanks I have tried that it is ok
    You mean the fuse is okay, or the heated window is now okay?
    Jan 2006
    Billinge
    The fuse is ok ,the switch on the dash lights up but the window dose not demiss
    Hmm, maybe a broken wire in the bottom of the screen bit? (guess). I guess a trip to your dealer if you're under warranty.
    Jan 2006
    Billinge
    Thanks Duncan . I will book it in
  1. Windscreens - Heat absorbing or heat reflecting?
    By Caveman_nige in forum General Motoring Chat
    Last Post: 4th February 2013, 22:09
  2. Rear heat window
    By crazyvectra2013 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd February 2013, 22:17
  3. rear windscreen heat fix
    By leedslads in forum Electrical & ICE (including SatNav)
    Last Post: 16th September 2012, 20:02
  4. For Sale: O/S & N/S rear window regs to fit vec c
    By SRIDAN in forum Parts for sale
    Last Post: 9th September 2012, 19:01
