Results 1 to 4 of 4
Thread: MOT failed steering issue
    Regular Member Darryl2.2DTI's Avatar
    Oct 2007
    Kilmarnock, Ayrshire
    Vehicle : Vauxhall Vectra C
    Trim : LS
    Engine : 2.2 DTI
    Year : 2003
    Mileage : 106000
    Default MOT failed steering issue
    howdy to all. vec went for its MOT today and failed on excessive free play on the passanger side front wheel. MOT tester says its the track rod that goes into the steering rack thats pumped. what sort of money you talking jst for the part. is it a big job to replace.
    thanks for any help. darryl.
    Regular Member brifen's Avatar
    Fareham
    Engine : 1.9 CDTI 150
    Hi mate, this is a job i've had to do fairly recently. I ended up changing both near side and off side, as the car was stripped so far I also put new track rod ends on too.
    If you just want to fix the problem and re-use old kit your looking at £25 for the inner tie rod kit (from Vx) and then labour on top.
    I'll tell you straight, that it is a complete pig of a job to get the old tie rod out. Vx must have some specialist tools to do it with to make it easy. I did manage in the end but ended up having to get someone to give me a hand with the car up on a proper ramp and the other person going in with a spanner from the top of the engine while I tackled it from the underneath. This is one job I'd be happy to pay to have done next time round, this was the OSF inner tie rod.
    You may also need a your trascking done after it too. Just count how many turns it taes to unscrew the old track rod end before fitting to the new inner tie rod.
    HTH,
    Bri.
    Oct 2007
    Trim : LS
    Engine : 2.2 DTI
    Year : 2003
    Mileage : 106000
    cheers man. jst as i though. typical that the parts arent to dear but it will be all the labour as usual that will cause the bill to be huge.
    Oct 2007
    Trim : LS
    Engine : 2.2 DTI
    Year : 2003
    Mileage : 106000
    well desided to take the car to the man who can. he replaced the broken part, welded the exhaust breckets back on and all for £98 all in. car passed mot after that. thanks for the advice brifan. pint for you
  1. Signum 2.0dti steering failed
    By BobG in forum Vectra C / Signum Troubleshooting
    Last Post: 30th November 2011, 18:54
  2. Failed MOT - Steering rack spindles????
    By glenboy in forum Suspension, Wheels & Brakes
    Last Post: 1st February 2009, 19:31
  3. Failed Power Steering
    By bigboynigs in forum Suspension, Wheels & Brakes
    Last Post: 15th December 2007, 17:44
  4. Power steering failed
    By Nealsey in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2007, 18:57
  5. Steering Failed ! 4th time !!
    By Ghosty621 in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2006, 22:13
