Results 1 to 10 of 11
Thread: Brake Pad
    Barra
    Default Brake Pad
    Hi
    i need your help, I have the yellow circle warning came up (no flashing) and I think it the brake pad indicator?
    what doe that mean? doe it mean I need the new brake pad and how much do yout hink it should cost?
    Blantyre
    Pads and discs are about £60 from Vx i think , fronts easy to do
    Barra
    Dont have Vx here locally, if I buy from online or ebay, what the best brand brake pad?
    11 Post(s)
    Get them from www.autovaux.co.uk
    Will be either a Vauxhall product, or matching OE.
    Did this light also have 3 lines either side of the circle along its circumference?
    Barra
    Its got a yellow circle with 3 little box outside of the yellow circle,
    11 Post(s)
    Quote Originally Posted by Gary1985 View Post
    Yep, that's the low brake pad warning light.
    However, it doesn't mean to say the pads have worn down. The wires to the sensors could be faulty.
    Ultimately you really need to have a good nose around and visually inspect all of the pads to see if they're worn.
    Plymouth
    Quote Originally Posted by spennny View Post
    More near £80
    Pads are £50 on their own..
    Regular Member no1baggiesfan's Avatar
    Jan 2008
    Newcastle
    Vehicle : 1.8 VVT SRi
    Pads and disc kit are £51.02 + vat and delivery, Mintex too
    Add a couple of quid if your car is sri or "sports"
    http://www.autovaux.co.uk/LoadPortal...bid=5&vnum=137
    Regular Member clightowler's Avatar
    Oct 2007
    Leeds
    Trim : SRI hatch
    Engine : z19dth
    Mileage : 110000
    Quote Originally Posted by no1baggiesfan View Post
    I use autovaux a lot for spares they can get just about anything and they really helpful, cannt recommaned them enough.
    Regular Member Swaite53's Avatar
    South Wales
    I believe that the sensor is only wired to the front pads. VX assumed that the front and rears would need replacing about the same time, and the front would wear out first and give an early warning for the rears.
  2. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  3. brake help please
    By sristeven1 in forum Suspension, Wheels & Brakes
    Last Post: 20th September 2010, 18:30
  4. yellow brake calliper brake set
    By The Gas Man in forum Parts for sale
    Last Post: 22nd July 2010, 22:41
  5. What brake pads for 2.8 V6 Signum??? 314mm brake discs
    By luke4487 in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 23:21
