Thread: EGR cleaning
    Jul 2009
    north east
    Default EGR cleaning
    now then
    following previous thread i tried cleaning the EGR valve on my 150 cdti. it's definaltly better than it was but not perfect. i used a cloth and some wd40. i'm taking it off again this weekend to do it properly, whats the best thing to clean the last bit of coke off?
    thanks
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Did you clean the boost sensor too..?
    Jul 2009
    north east
    i cleaned inside both holes that were filled with black stuff. one went to a pipe and the other to the manifold i think. i also cleaned the electric connector. where and what is the boost sensor?
    Lancashire
    Trim : XP NAV
    Quote Originally Posted by jenko View Post
    Its next to the EGR (on the left as you look at it), it has a electric plug connected on top of it (it has a blue Bosch sticker on it) - its only held on by one torx screw and it pulls out - it has a small element inside, take care not to damage it - I just drowned mine with carb cleaner and allowed to dry, made a big difference to the smoothness of the power delivery.
    Regular Member installer's Avatar
    Nottingham
    now then
    Cleaned mine 2 or 3 times now.
    I`ve used wynns carb cleaner and yes improved it, but to me, still wasn`t clean.
    So I used Bilberry safe wheel cleaner.Neat in a bucket or tub, left to soak, then scrubbed with a tooth brush, then put back in, then repeated.
    In the end looked like just bought a new one from vxl.
    So I recommend Bilberry Safe Wheel Cleaner,blows carb cleaner out the water.
    Glasgow
    has any one found you could get the cylinder out? i couldnt so just left it it in.. dont know if that matters or not..? i tried hammering and everything!
  1. Cleaning egr
    By morrisseyno1 in forum Vectra C / Signum Troubleshooting
    Last Post: 4th September 2011, 20:16
  2. egr cleaning
    By hbomb in forum Engine & Drivetrain
    Last Post: 8th July 2011, 18:00
  3. cleaning help
    By davidlewis24 in forum Detailing and Car Care Discussion
    Last Post: 13th April 2009, 20:37
  4. DPF Cleaning?
    By parapaul in forum Diesel Engine related
    Last Post: 9th October 2007, 13:52
  5. Cleaning
    By thegoldenbullet in forum Detailing and Car Care Discussion
    Last Post: 11th August 2007, 22:13
