Thread: speedo
    Full Member paul.sessions's Avatar
    leighton buzzard
    Default speedo
    hi i am aware that the mileage is stored in two places. if i bought new speedo or used one could i swap the eeprom chip in them,, this is where its held?? or regarding new ones is there any one one here that can set the mileage via tech2
    thanks
    paul
    milton keynes
    Quote Originally Posted by paul.sessions View Post
    thanks
    paul
    Only new clocks can be set via tech2 , they have the write once eprom (not eeprom).Otherwise you will need to go to a clock correction company if the clocks need changing.
    leighton buzzard
    Quote Originally Posted by kman247 View Post
    do you not think they could be unsoldered and swapped?
    milton keynes
    i wouldnt suggest it , the eprom may hold all the info on the other hand it may go into delivery mode or even go faulty. I have been working at component level for many years and wouldnt try it on good clocks , i have a spare set here i could try it on , when i get the chance. if it goes into delivery mode this could cause an issue if you havent recorded all the idents first.
    leighton buzzard
    cool yeah did think there might be problems with that cheers richard
    Forum Moderator John LE's Avatar
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    You could get one of those people that do "digital mileage correction". I know it sounds illegal but you are simply putting the mileage back to what it houd be
    leighton buzzard
    yeah did think that but isnt it quite expensive??
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Not sure buddy never done it lol. Just a suggestion
  1. GPS v SPEEDO
    By savage. in forum General Chat
    Last Post: 20th April 2009, 14:23
  2. no speedo
    By frazandsaima in forum Engine & Drivetrain
    Last Post: 25th January 2009, 23:53
  3. Speedo..
    By C19_CJB in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2005, 15:37
