Thread: Front Fogs mistng up
    Regular Member DurhamRed's Avatar
    Co. Durham
    Vehicle : Vectra SRi
    Engine : 1.8VVTi
    Default Front Fogs mistng up
    Anyone had the same problem? Mines an 06 SRi and ever since we had the heavy rain 3 weeks ago my fogs are misted up. I have left the car parked outside the house with the foglights on for about 20 minutes which does remove the moisture only for it to ****** return the next morning!
    Anyone got any ideas on how to rid the fogs of the moisture permanently?
    This has only been an issue for me since the bad weather but I'm worried it could rot the foglight units unless I get rid of the moisture. By the way I can see no water inside the units. Just condensation.
    11 Post(s)
    You know those small bags of desiccant (moisture absorber) that you get in the bottom of the box of a new pair of shoes, or in the box of some new electrical equipment. Well, undo the cap where you access the bulb, and place the small bag into it and refit the cap.
    I did this 3 months ago and since then no more misted up nearside foglight.
    Regular Member KSD's Avatar
    Aug 2007
    Cupar, Fife
    My nearside foglight is always misted up. Not done owt about it yet tho! Will strip it down and sort I think. Not sure what is causing it to condense, must be a poor seal.
    Surrey
    Drill a 3mm hole in cover, I am sure it's a pressure thing which draws the water in through the poor seal.
    11 Post(s)
    Quote Originally Posted by steve1975l View Post
    Drill a 3mm hole in cover.
    I did that and ended up with mucky water in the foglight after driving through a deep puddle. Had to take the fog light off and wash it out, dry it, then block the hole up. 2 days later it misted up again, but since fitting the moisture absorber it's not fogged up since.
    Oct 2006
    Waterloo, Liverpool
    8 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    What I did was drill a hole in the cover as Steve1975l did, which de-misted the foglamp, and to avoid your problem I plugged the hole with a plastic plug/grommet thing I had lying about. Best of both worlds methinks. To de-mist I can either unscrew the cover or simply remove the 'plug' and replace one or the other after the foglight has cleared.
    Surrey
    I haven't had any problems with it since and I drive down flooded country lanes. It must have been a deep puddle.
    Lancashire
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by john_k_sri View Post
    Following this good mans advice, I pierced my cover with a drawing pin, and its been perfect since, also the hole is small enough to not let water into the foglight (as I have been checking for this).
    11 Post(s)
    It was when the floods were about a few months ago.
  1. 06 2.2 sri front fogs
    By 06sri in forum Bodywork & Interior
    Last Post: 18th June 2012, 19:49
  2. Front fogs
    By bigmac in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2010, 00:20
  3. front fogs
    By cbl1985 in forum Electrical & ICE (including SatNav)
    Last Post: 5th February 2010, 19:10
  4. front fogs
    By derby4life in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2007, 09:55
  5. Front fogs
    By fishphone in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2007, 12:56
