Results 1 to 10 of 23
Thread: Any plumbers here?
    Regular Member arkhan78's Avatar
    Nov 2007
    Leeds
    Default Any plumbers here?
    Hi all
    need some advice and maybe a plumber for the doncaster area.
    Girlfriends house has got a Ideal boiler fitted which should heat water and run the central heating. However had a guy in to fit the new bath room and shower. Since then the boiler is making gurgling sounds when igniting, no HOT water only warm and the central heating doesnt work at all.
    So basically looking for a good plumber in the doncaster area to have a look and fix for a good price without robbing me.
    look forward to any advice or contacts
    Surrey
    Air in the system.
    Regular Member AdeyCorp's Avatar
    Chesterfield
    DitchP might be able to help, he is in nottingham.
    Quote Originally Posted by steve1975l View Post
    Air in the system.
    sounds like it to me, depending on the system probably just requires bleeding hth ......
    East Midlands
    ?Have you asked the bathroom fitter if the problem is at all caused by his work..just a thought.
    Regular Member vanquis1979's Avatar
    gainsborough
    is it an isar 24 or isar 30 there known for air locks
    Regular Member steve0's Avatar
    UK
    First check the pressure on the boiler, there will be a pressure gauge somewhere on the front of the boiler, this should be somewhere between 1 and 1 and a half bar. If its below 1 bar that is most likely your problem.
    To rectify top up the system using the filling loop, this will more than likely be a chrome braded hose somewhere below the boiler connecting the cold water pipe 15mm to a larger 22mm pipe being the central heating return.
    On the cold water pipe side there should be some kind of isolation valve which can be opened up using either a slotted screwdriver or by an attached lever similar to what you would see on a washing machine.
    Once opened you will see the pressure raise on the pressure gauge. Switch back of when 1 and a half bar is reached.
    Now bleed all your radiators, downstairs first then upstairs. If air is present the pressure will again drop while the air is being replaced by water, dont panic just top the boiler back up as above.
    End result should be all radiators full of water and pressure gauge showing between 1 and 1 and a half bar.
    Switch on the boiler, expect some initial rumbling and funny noises possibly with slight pressure drop again, this will just be air in the boiler exiting through an internal automatic air vent.
    Should quieten up within a minute or two and hopefully all will be well.
    Did the plumber fit a new bathroom radiator, if so it will be his work and the reason why the pressure has dropped.
    Hope this helps.
    Quote Originally Posted by steve0 View Post
    Hope this helps.
    Great 'How2' if it's a pressure system .......
    UK
    Quote Originally Posted by Tadpole View Post
    Arkhan's original quote states 'ideal boiler which runs both hot water and central heating'. This suggests it is a combination boiler making the above info totally relevent mate. If its not a combi system then the original statement is wrong.
    I wasn't getting at you mate I ment it as it was ......
  1. Any plumbers in here
    By dannyjpuk in forum General Chat
    Last Post: 26th January 2012, 09:17
  2. Any plumbers on here?
    By lee gsi in forum The 'Off Topic' room
    Last Post: 30th December 2011, 23:18
  3. Plumbers
    By Daywalker in forum General Chat
    Last Post: 21st October 2010, 18:02
  4. any plumbers on here
    By neverlandandy in forum The 'Off Topic' room
    Last Post: 30th September 2009, 22:07
  5. Any Plumbers on here ?
    By markm in forum The 'Off Topic' room
    Last Post: 6th March 2008, 23:27
