Thread: Is the tailgate glass bonded in?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Default Is the tailgate glass bonded in?
    As above. I have a heavily scratched rear glass and want to know if i can change it myself. Thanks in advance
    lanark
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    i would assume it would be bonded the same as the front
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Well i thought that but seeing as the side quarterlights can be removed i thought the tailgate glass may be the same.
    Mileage : 000
    Whilst mine is the estate. Mine does look bonded in as you can see the edge of the glass. So I too would presume the hatchback to be bonded too.
    Regular Member axelf's Avatar
    chester le street
    yes m8 the rear window is bonded in, it can be taken out , but use a windscreen comp to do it. They have to cut it out with cheese wire, then old bond on car scrapped down to leave about 1 mm then they re activate this, then they put on new bond then the window goes in.It will take about 2hrs to do the job then 3 hrs for the bond to dry...Cant wash the car for at least 24 hrs after and also drive with the windows up for 24 hrs, or it will push the window out.....hope this helps....
  1. Bonded ribbons
    By Dannyboy444 in forum Electrical & ICE (including SatNav)
    Last Post: 1st August 2012, 14:02
  2. Just bonded my swirl flaps open!
    By Richard.roberts in forum Engine & Drivetrain
    Last Post: 10th June 2012, 21:40
  3. all that glass on a sig
    By m20_swe in forum Vectra C / Signum Car Chat
    Last Post: 22nd September 2010, 15:38
  4. sikaflex bonded front splitter removal
    By robinhood66 in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2007, 17:59
bonded tailgate
vectra c estate tailgate glass
