Thread: Quick detailing advice please
    Regular Member djr69uk's Avatar
    Midlands
    Default Quick detailing advice please
    Hi guys
    I've met several of you detailers (Lump, Scott and Phil) and you each kindly gave me some advice about getting my car sorted - which I appreciated but I need a quick re-cap as my memory isn't great thanks to Mr Carlsberg!
    Basically, I'm getting married weekend after next and my car is a bit of a state with a few light scratches and some paint splatter (off the road) up the side which I need to get rid of. Phil helped me find something that worked on the paint splatter, which was Poorboys SSR (I'm getting some SSR 2.5 to get rid of the swirling as well), but I just need to put together a quick shopping list so I can have a go at it this weekend.
    So, first off I need a list of stuff for an absolute detailing beginner, who is on a tight budget... and secondly I would like some application guidance. Finally, can someone please recommend somewhere I can buy the products that will deliver to me next day - assuming it comes from an online shop.
    In terms of the detailing, I think the order is:
    1. Wash
    2. Use swirl compound
    3. Wash
    4 Use polish
    5 Use wax
    ... but I might be completely wrong here.
    I do have an old machine polisher... but would need some new buffing pads for it. I also bought some micro-fibre towels and a mitt recently.
    Thanks in advance chaps.
    Mileage : 000
    I would recomend.
    1) wash
    2)clay
    3)wash
    4)paint cleaner
    5)swirl removal polish
    6)polish (if needed)
    7)wax or sealent
    That is what I would do if starting from scratch so to speak.
    You could also apply a sealent before you put the wax on, wax always goes on after a sealent as a sealent will not bond to a wax if the wax is applied first.
    Hope this is some help.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Dependant on had bad your swirls are, TBH you are only likely to be able to 'remove' them using a machine to polish - by hand you're best bet is to mask them with something along the lines of AG SRP or PB Blackhole (which works well on reds too).
    Cambridgeshire
    I do it slightly differently.
    Have a look here if you like mate....my latest detail that I did with a step by step
    Midlands
    ok thanks guys... i'll add clay into the equation.
    what clay and wax are recommended? also where should i get all this stuff from? is there a one stop shop internet shop?
    thanks
    Mileage : 000
    Have a look on www.elitecarcar.co.uk if you put in vectrac in the discoount box you will get some off the price, might be about 10% I forget.
    There are many wax,s to choose from. But Colinite 915 seems to be one of the longest lasting.
    I am trying out a sealent called KP1000P it is made by Finish Kare. I must admit I am very impressed with it so far.
    But one of my favorite wax,s has to be Victoria Concours Wax. I think it is brilliant on my Star Silver motor.
    Midlands
    cheers for the tips Ed... I got some collinite off Lump when I saw him - so I'll use that. Could do with some tips to applying it though lol! Unfortunately the elitecarplace is on hols until august 4th i found this place though...
    http://www.abberley-outdoor.co.uk/
    anyone know if they are any good - or if we get discounts there too?
    Mileage : 000
    Tips on applying Colinite. I would suggest applying it to one panel at a time. That is applying it not too thick, then rubbing it off when it has hazed over. Don,t leave it too long before you remove it as it can be a bit of a pig to get off. I have been known to go over all of the car, then when you get to the last part to remove it has very hard to remove.If you want to put a second coat or so on, then you will need to wait 24 hours for the previous coat to "cure", as the solvents in the next coat will remove the previous coat.
  1. First go at detailing - Advice required Please
    By alcutler in forum Detailing and Car Care Discussion
    Last Post: 9th April 2012, 21:04
  2. Help..advice quick please..
    By monkeez in forum Vectra C / Signum Car Chat
    Last Post: 28th May 2008, 15:44
  3. quick detailing question
    By pogo in forum Detailing and Car Care Discussion
    Last Post: 13th June 2007, 17:06
  4. quick detailing question
    Last Post: 13th June 2007, 14:24
  5. Megs Quick Detailing Spray
    By Spikey© in forum Detailing and Car Care Discussion
    Last Post: 24th April 2006, 19:57
