Thread: intermittant fault
    mansfield
    Default intermittant fault
    as im driving along no matter what speed or revs, intermittantly the car seems to die and then come back to life within 1 second,
    its like a flat spot if you will but not actually having the flat spot.
    i have changed the EGR and the Intercooler as that was causing the last problems i had
    any ideas peeps?
    steve
    Bristol
    Vehicle : CDTI 150
    What engine you running?
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    hes got a cdti
    3rd injector ?
    mansfield
    z19dth (1.9 cdti 150)
    i was thinking along the lines of the 3rd injector but dont know the characteristics of it going
    Bristol
    Vehicle : CDTI 150
    Starts with the occasional 'miss' then later the car will kangaroo lots lose power and EML.
    Check if the 3rd inj has the modified blue plug. New plug is about £12 easy to fit if you can handle a soldering iron
    mansfield
    went out in the car last night and it finally has thrown up a eml code for the problem (well i think)
    driving along and the power just died, like the engine had cut out.
    pulled over turned her off and then started her again and drove fine all the way home, got back plugged the car into OP COM and it brought up these codes:
    P1125 - Throttle Actuator Feedback Signal Range/Performance
    (21) - Not present
    P0638 - Electronic Throttle Control Circuit open
    (04) - Not present
    any ideas on these?
  1. Hatch Won't Open - intermittant fault
    By wafoo in forum Bodywork & Interior
    Last Post: 2nd February 2013, 20:33
  2. Intermittant HID fault
    By Big Dave in forum Electrical & ICE (including SatNav)
    Last Post: 31st December 2011, 04:48
  3. Intermittant limp mode....HELP!!
    By superfox233 in forum Engine & Drivetrain
    Last Post: 5th February 2011, 10:55
  4. intermittant smoking
    By Xpolicevectra in forum Engine & Drivetrain
    Last Post: 5th April 2010, 00:42
  5. Roller Steering Controls - Intermittant fault
    By MCD in forum Electrical & ICE (including SatNav)
    Last Post: 21st March 2009, 11:29
