Thread: Vectra 2.6 Diagnostic codes P0170 & P0173 Found
    Jul 2009
    Prudhoe
    confused Vectra 2.6 Diagnostic codes P0170 & P0173 Found
    can someone give me a little help with these codes please as the diagnostic shows the following:
    P0170 Fuel Trim Bank 1
    P0173 Fuel Trim Malfunction Bank 2
    The engine omissions light has been reset and the car runs fine no loss of performance,but after 350 miles the light has come back on and the same faults are listed. Can anybody help please about how to sort this problem.
    West
    Firstly check for any vacuum leaks, if there are none, you could need a new mass airflow meter...
    NULL
    According auto data
    Intake leak, AIR system, Fuel pressure/pump, Injetor(s), EVAP canister purge valve, HO2S
    hope this helps
    NULL
    i would check the EVAP canister purge valve. this is behind the air filter with 2 hoses. check for leaks.
    Then check the HO2S (heated oxygen sensor) in each downpipe make sure the wires look ok, to behonest i would not expect them both to have gone down and if one had then only one bank would be playing up.
    Jul 2009
    Prudhoe
    Thanx for your replies now I have somewhere to start, will post any findings. Thanx again
  1. 3.2 - P0170 & P0173 fault codes
    By Jay-C in forum Engine & Drivetrain
    Last Post: 18th December 2013, 14:19
  2. GM Diagnostic Fault/Trouble Codes
    By GazVXLINE170 in forum Vectra C / Signum Troubleshooting
    Last Post: 26th November 2010, 01:07
  3. U480 diagnostic Scanner, can engine be running when reading codes
    By wickedwillie in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2010, 11:58
  4. P0170 & p0173
    By REDMGB in forum Engine & Drivetrain
    Last Post: 29th October 2009, 23:47
  5. 3.2 GSI vectra P0170 and P0173
    By fuzzbomUK in forum Engine & Drivetrain
    Last Post: 3rd August 2008, 22:13
p0173 vectra
vectra codigo P0170 y P0173
p0170 vectra c
vectra 2.6 p0173
fuel trim
p0173 opel vectra
vectra b p0173
p0173 vauxhall
