Thread: Loose Gear Knob
    Regular Member phil67's Avatar
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    Default Loose Gear Knob
    A quickie for you experts, my gear knob appears to be loose movement up and down which makes a clicking noise when pressed, but only when the weather is warm, on a coldish day its ok.
    How are they fixed if its glued on that would make some sense of when the weather has warmed up?
    Any ideas or suggestions?
    Regular Member nigec's Avatar
    barnsley
    Quote Originally Posted by phil67 View Post
    Mine just comes off in my hands from time to time as im going through the gears, i just turn it and bang it back on with my fist, ive got used to it accuring, scares the passengers though
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by nigec View Post
    Ooooo errr missus lol
    Merseyside
    Dont do what I did and replace it with an aftermarket jobby. It spoils the look. If its badly worn or the grip inside the gear knob is worn then get a new one.
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    So how exactly is the gear knob secured???
    Full Member spennny's Avatar
    Blantyre
    Or get a VXR one
    Regular Member sparky71a's Avatar
    Apr 2006
    At the Garage
    Yep my previous 2.2 an o5 plate had this fault.
    Simple fix,put a little and i mean a little superglue inside the handle at the top,don't get it down the edges,THEN HIT IT AS HARD AS YOU BL88DY CAN BACK ON!!
    Mine never came of again........
    Which is great because the first time it did was going into fifth on the outside lane on the M5
    Regular Member sri_joe's Avatar
    Accrington
    i have the same problem only happend today, anybody know if a vec b irmy gearknob will go in my 07 vectra c?
    Regular Member DurhamRed's Avatar
    Co. Durham
    Vehicle : Vectra SRi
    Engine : 1.8VVTi
    Got mine fixed under warranty - VX dealer stuck loads of gooey black stuff inside the knob and told me to let it set for a day or so. As it was a Friday i did just that and left the car all weekend, now the knob is stuck on and no further probs at all.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Sounds like tigerseal they used
  1. gear selector come loose
    By nelly452 in forum Engine & Drivetrain
    Last Post: 3rd October 2011, 21:55
  2. Gear Knob is loose
    By aerodynamic18 in forum Bodywork & Interior
    Last Post: 31st August 2011, 06:50
  3. Gear Knob loose?
    By lencuff in forum Bodywork & Interior
    Last Post: 7th June 2011, 22:59
  4. gear stick loose
    By reeseandellie in forum Engine & Drivetrain
    Last Post: 7th June 2011, 22:33
  5. loose gear knob
    By studmuffin in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2010, 21:42
corsa d gear knob loose
opel vectra gear knob loose
vectra gear knob repair 07
vectra loose gear knob
vectra c gear knob clicks site:www.vectra-c.com
loose gear knob vectra
