Thread: hid xenon conversion
    Apr 2009
    renfrewshire
    Thumbs up hid xenon conversion
    Finaly getin round to converting to hid from hid direct only thing i dont understand is the watage there are the 35w or 50w, eney idea of the best one to buy?
    cheers for the help.
    Stockton on Tees
    you may already be aware of this but most of these kits are for dipped beam only. When you put your full whack high beam on its just the standard bulbs!!!
    Regular Member csd_19's Avatar
    Oct 2006
    Aberdeen
    Engine : 2.8T
    Should be the 35W ones mate, 50W are only for off-road ie show use
    Regular Member mammix2's Avatar
    Brighton
    ftmo
    Let me know if you have any trouble with the ballasts randomly not starting, especially in the wet.
    I've recently had problems with a set from HID direct, which ive already sent back once but they were convinced that it was just the capacitors that were at fault. They replaced the capacitors and returned the kit to me, but i'll have to wait until the cars back from thre spray shop to test them fully.
    It says in the blurb that the ballasts are 100% waterproof (cough cough!) I dont think so...
    If you get problems, carefully (so it doesnt invalidate the warranty) unscrew and take the back plate off the ballasts and check the amount of potting solution that has been put in there. Mine were both only half full exposing alot of electronic components to the damp air.
    Fingers crossed you wont get any problems with your kit :-)
    Apr 2009
    renfrewshire
    Quote Originally Posted by Stephen S View Post
    I dident know that mate cheers for teling me!!
    Do you know of a beter powerd kit or bulb for both dip and main beem?
    cheers ftmo
    Regular Member KTM Chris's Avatar
    Nov 2007
    North Lincolnshire
    Quote Originally Posted by ftmo View Post
    cheers ftmo
    The Vectra uses seperate bulbs for dipped and main beam - to have HID dipped and main beams you will need to buy two HID kits.
    Stockton on Tees
    IMO its not worth buying 2 kits so you can have a main beam too. with the type of driving i do i maybe only use my main beam 2% of the time. the extra light that will be emitted will probably not require the main beam anyway.
    Nov 2007
    North Lincolnshire
    Totally agree with Stephen S. I'm also a bit scepital about HID's functioning correctly when 'flashed'. I think you'll find with dipped HID's you won't need main beam anyway!
    Edinburgh
    Quote Originally Posted by KTM Chris View Post
    I think the HIDs would be bright on the first flash however if you flashed several times the rest would be quite dim. also I think it very much shorten's the life of ballasts.
    With HIDs in the dipped you'll never use your main beam again. I found the HIDs drowned out the mainbeam anyways.
  1. HID Xenon Conversion Kits
    By kevinmc in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2012, 00:44
  2. Factory Xenon Conversion
    By Maverick in forum Non Vectra C/Signum Album
    Last Post: 3rd January 2012, 14:59
  3. hid xenon conversion kit 4 INSIGNIA
    By jazzy jay in forum Insignia car chat
    Last Post: 11th February 2010, 15:17
  4. hid xenon conversion
    By ftmo in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2009, 20:14
  5. Piaa Xenon Conversion
    By LEW1S2006 in forum Vectra C / Signum Car Chat
    Last Post: 7th September 2008, 23:09
