Results 1 to 10 of 11
Thread: Boot power conversion thing
    Newcastle under Lyme
    Default Boot power conversion thing
    Ive had a look through the how to's and cant find one and ive also searched.
    Im looking for a boot power conversion thing but cant think what terminology I would use in a search.
    Does anyone know what im on about?
    Regular Member fingers66's Avatar
    Carpe Diem
    do you mean this
    spot on. Is it just a cigarette lighter int he boot?
    Regular Member Dippy-Vx-line Red's Avatar
    Earlston (Scottish Borders)
    Hi.Was thinking about this mod too..Was just wondering if this would be any good...
    http://cgi.ebay.co.uk/12v-Motorcycle...lenotsupported
    Hunwick, County Durham.
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    Quote Originally Posted by dippy27 View Post
    it mite work, but it depends on what current the holder is rated at, it should be 10A but bikes run slightly lower currents than cars.
    if you have a halfords close by, pop in and look at theres, its a one that goes into the original cig lighter and extends it by 3mtrs and also lets you use the original cig lighter by "piggy backing" it. i bought one of these and just choped the end off and used the wire. i will try and find the link.
    here is the link http://www.halfords.com/webapp/wcs/s...egoryId_165489 or search their website for "Halfords 2 Way Rear Extension Socket".
    if there is no How2 for this and anyone wants some advice, just PM me, or post in here.
    mick.
    K bought all the parts and have the circuit in place so one end goes to fuse box other to earth. What fuse do I put in as a 15amp blew the fuse in the adapter I plugged in and 5a didnt blow either and didnt do much. Tried 10a which didnt blow either fuse but smoke started to appear from the adapter.
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    how have you wired it up??
    what are you trying to run from the socket?? no smoke should come from anywhere!
    fuse board to inline fuse then connected to the Lighter socket. A wire coming from that to a sanded earth point.
    Tried the fuses as above.
    Just a thought would it matter which way round I have the positive and negative plugged in on the lighter socket?
    south wales
    the point in the middle of the fag liter is positive and the outer of the fag lighter is negative
    May be the problem will have to check. Wont reply for a few days as im off on a friends stag weekend - im not being ignorant.
  1. Torque to Power Conversion...
    By nutron in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2012, 10:29
  2. Replies: 9
    Last Post: 2nd October 2010, 18:10
  3. power in boot
    By middler31 in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2008, 18:57
