Thread: 3" air-intake for 2.0t - well worth it
    Regular Member exitusletalis's Avatar
    Helsinki
    StatsVehicle Info
    Default 3" air-intake for 2.0t - well worth it
    Did a few mods to my 2.0 turbo air-intake:
    - 3" flexi duct from the grill
    - airbox mod and K&N panelfilter
    - 3" alloy intaketube replacement from MAF to turbo
    I should have done it all much earlier. The 3" replacement tube gives the turbo a lot more boost in high revs, it is definitely noticeable. Cheap and easy to put together yourself.. All you need is:
    - a 90degree 3" alloy bend
    - 2 mounts for vacuum pipes
    - some epoxy glue or something else to fit the mounts
    - 3" silicone coupler
    - a 90degree 3"->2.5" silicone reducehose
    cut the alloy bend to fit, drill 2 holes for the vacuum hoses, attach them with glue or other method of your choise, finally fit in with the silicone couplers. recommended.
    Regular Member rushy's Avatar
    StatsVehicle Info
    Nice work mate. You could remove the MAF sensor from its housing, drill a hole in your ally tubing and pop it in there, this way you get rid of the smaller MAF pipework.
    Jan 2006
    Dalriada
    StatsVehicle Info
    That look's very good mate
    So it's worth the work then bud??
    Regular Member big O's Avatar
    Good old Sunny Scunny!!!!
    StatsVehicle Info
    I might have a bash at this, nice work exitusletalis
    Regular Member pogo's Avatar
    Feb 2006
    StatsVehicle Info
    where did you get the parts from mate?
    StatsVehicle Info
    Quote Originally Posted by pogo View Post
    i was thinking the same, but the 3" alloy pipe you could get your local powerflow dealer to make one up for you. It's the other parts i'm struggling with. I'm gonna have a look on Ebay.
    Helsinki
    StatsVehicle Info
    I got mine from a local finnish autoparts dealer. The vacuumhose mounts and the flexiduct are from a hardware store. I'm pretty sure you can find the stuff just about anywhere, but if youre struggling have a look on ebay.. for example this shop:
    http://stores.shop.ebay.co.uk/ACEpar...__W0QQ_armrsZ1
    oxford
    StatsVehicle Info
    hi mate what thickness is the pipe.
    thanks.
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    StatsVehicle Info
    Looks boss that mate does anyone know how wide the pipe is on the 2.2 direct?
    Helsinki
    StatsVehicle Info
    thickness of the alloy pipe wall is approx 1.5mm. I'm sure you can use almost any kind of pipe. I don't know about z22se/yh, sorry.
  1. No " How Much Is It Worth Section "
    By spennny in forum General Chat
    Last Post: 6th June 2009, 21:28
  2. Put in the 3.2 air intake today on my 2.2 Direct Well worth it!
    By sparky71a in forum Vectra C / Signum Car Chat
    Last Post: 6th August 2008, 11:24
  3. 19"snowflakes what are they worth?
    By Teza in forum General Chat
    Last Post: 23rd April 2007, 11:27
