Results 1 to 10 of 10
Thread: io play install problems
    Regular Member turbohaggis's Avatar
    Jul 2008
    Scotland (twinned with Libya)
    Red face io play install problems
    Having bought an io play and an SOT-078 lead (my car has the cdr2005 stereo), i tried fitting it today.
    I have power at the io as the buttons are lit up dimly and the car stereo, but there is no sound and i am unable to put the the 4digit passcode to unlock the cdr2005. Its as if the io is intefering with the supply to the stereo.
    If i unplug the io from the loom/loop, and join the sot lead together so it makes on long loom straight into the cdr2005, only then am i able to input the security code and all works.
    Anyone here had any similar probs, i phoned the io play helpline, and they reckoned it could be a faulty SOT lead, which i bought off ebay for £9.
    Sorry for rambling on, but i was looking forward to getting this fitted
    Cheers folks
    New Member AVectraOwner's Avatar
    Sep 2009
    Wiltshire
    Hi, It sounds like I have simular problems with my iO Play install. When connecting the iO Play with loom it affects the radio and it won't allow me to enter the 4 digit code. Were you able to get yours working?
    Cheers ;-)
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    Different slightly but when i fitted my parrot i had dimly lit up buttons and it wouldnt work this was due to the lives being back to front on the vec compared to the standard parrot wiring and once swapped over all worked.... maybe related maybe not (also cdr2005).... hope ya get it sorted
    Jan 2009
    WGAF#5
    Quote Originally Posted by steve View Post
    yep revers the feeds sounds like your getting insufficient current to power up the items correctly
    Regular Member nick-v2.2's Avatar
    Nottingham
    when i originally had my ccr2006 when trying to fit my parrot ck3100, either way my stereo wouldn't work properly.
    solved by powering the parrot seperately from the cig lighter.
    Jul 2008
    Quote Originally Posted by AVectraOwner View Post
    Cheers ;-)
    Nope, its still sitting here in its box, i gave up!!
    I have emailed the advice line on the i/o play website and never had a reply. They had a free phone number you could call, but guess what, they have now made it a premium rate number at £1 a minute, hence why they probably never reply to emails
    Where did you buy your sot lead? I bought mine from ebay and they said that might be the problem, you can one from us at £20!! Yeah! right, and i bet it gives me the same fault!
    I have even tried to buy the fitting voucher online from there site, and even that doesnt work, it wont accept any payment card, even emailed that to them saying i want to buy and pay for it, but no answer, honestly, there customer service is the worst i have ever dealt with. I wont buy anything from the Armour All group again!!
    Sep 2009
    Wiltshire
    I have the cdr2005, the lights on the iO Play console are dim and the cdr2005 looks like it's powering on and off. most defiantly got to be a power issue.
    I got my lead from ebay also, think I paid about £12 for it. looking at the lead it swaps the red and yellow cables round. anything else I need to look for?
    Jan 2009
    WGAF#5
    as said above - does the ioplay need a permanant live feed ?? if so take it from the cigarette lighter
    Jul 2008
    Quote Originally Posted by deztroyer View Post
    I'm on holiday after this week, so im gonna give it another bash and i will try what you say deztroyer and take a feed from the cigarette lighter. Cheers Fella
    AVectraowner, i bought mine for £12 from ebay also, so likely its the same cable, i will keep this thread informed if/when i get it working
    Regular Member blue estate's Avatar
    Feb 2008
    oh well.. I tried..
    I have the IO play with the CD70, works fine using the SOT lead i had from ebay like you guys.. and as said 12v feed from the cig lighter
  1. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 12th November 2019, 09:21
  2. Problems with active subwoofer install
    By suj786 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd October 2010, 00:04
  3. Drive & Play install
    By SignumPhil in forum Electrical & ICE (including SatNav)
    Last Post: 13th November 2007, 14:15
  4. HK Drive and Play install
    By DNS in forum Electrical & ICE (including SatNav)
    Last Post: 2nd November 2007, 10:58
  5. Pioneer Install Problems
    By bluebirds1975 in forum Electrical & ICE (including SatNav)
    Last Post: 9th March 2007, 09:49
