Thread: Help with boiler required..
    West
    Default Help with boiler required..
    Any folks out there that know there stuff... i would be greatfull for the advice.
    The Boiler is a combi Vokera Option aprox 4 years old, the symptoms are: The pressure is increasing too high.
    I have looked at the Pressure vessel & it's holding pressure.
    I have removed the mains fill up loop & it's not a leaking valve on that side.
    I have narrowed it down to the hot water heat exchanger must have failed & is passing mains water into the heating system...
    Now my question is:
    Is it worth having the heater exchanger replaced & roughly what is the likely cost?
    Or should i use the cash i have saved towards a new car & have a complete new boiler installed?
    Thanks in advance...
    West
    Any one?
    Apr 2009
    on a motorway somewhere
    See www.heatingspares247.com for possible prices (click on boiler parts and then heat exchangers)
    Also see http://www.diynot.com/forums/viewtopic.php?p=700249 for some pretty negative comments about these boilers.
    Pays your money and takes your choice!
    Sue you can find much more if you Google "Vokera Boilers".
    Full Member chunkster's Avatar
    North east HQ
    have a look here, you may need the part number for the right one,
    Wayne -
    Regular Member peppered's Avatar
    Jul 2009
    Thumbs up
    Now my question is:
    Get shot mate - vokera have never been much cop - try to get a vaillant/gloworm or a worcester. It'll cost you a bit more but worth it!!
    Regular Member mradz's Avatar
    Northants
    any of those makes are a good choice and come well backed up too!
    Regular Member Matty H's Avatar
    Bristol
    I know you say you've checked this but are you sure the expansion vessel is sound? It's a very common problem in Vokeras
    West
    Quote Originally Posted by Matty H View Post
    Yes the vessel is holding the set pressure...
    If i turn the hot water mains inlet off, the system is fine & not gaining pressure... but once the hot water is in operation the pressure is rising very quickly
    Bristol
    Do you get a similar quick pressure rise on heating only? Not just the normal rise from expansion?
    Could well be your assumption on the heat exchanger then
  1. Noisy Boiler
    By crispy007 in forum General Chat
    Last Post: 21st November 2011, 18:52
  2. Gas boiler broke? or is it?
    By spoons in forum General Chat
    Last Post: 22nd September 2010, 13:46
  3. Help with boiler required..
    By Gr4eme in forum The 'Off Topic' room
    Last Post: 17th May 2009, 22:23
  4. any boiler guys here?
    By gallag in forum General Chat
    Last Post: 5th May 2009, 19:44
  5. Boiler Advice
    By leeds vectra in forum General Chat
    Last Post: 9th February 2007, 00:47
