Results 1 to 10 of 13
Thread: Washers not working :(
    Plymouth
    Default Washers not working :(
    I let the washers run dry.. gone to fill up.. tried the washers again... nothing..
    I can hear what i presume is the pum whirling away... but i get not water... Nothing at the back nothing at the front...
    Is this simply just a blockage from some poss gunk??
    Or could it be something else?
    Is there any additves i can add to help clear the blockage or is it a rip it out clean it by hand job?
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    possibly jammed some crap in the pipe lines mate I have had to blow through them in the past to clear it
    Edinburgh
    bummer mate, hope you get it sorted without too much hassle
    does the rear work or are all of them busted atm?
    Plymouth
    Quote Originally Posted by Sean-2.2Direct View Post
    I may give blowing it a go... will disconnect the new spray jets though!! dont wanna clog those up!!
    Quote Originally Posted by knoxvillain View Post
    Cheers!!! Fingers crossed it wont take much effort
    Apr 2008
    Liverpool
    Quote Originally Posted by Diet1985 View Post
    Its not to hard I found out last time it was this by looking in to the washer bottle there was loads of flaky bits floating around
    There is a filter in the washer bottle that gets full of crap. Wheel arch liner out, remove pump and give it a clean
    Plymouth
    weird.... just gone out and it worked :s
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    It will clog again ...mine done this...turn the wheels hardlock to the left..acess 2/3 torx... undo those...pull back inner arch and pop out washer pump, and you will have access to the rubber screen which will be full on gunk..clean and drain..
    wulllA
    Plymouth
    Quote Originally Posted by Dose View Post
    wulllA
    Cheers mate....
    Job for the weekend me thinks
    May be time to reduce the medication a little Dan think your hallucinating ............
  1. Windscreen washers stopped working
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2011, 18:10
  2. window washers not working and
    By wiganrl in forum Vectra C / Signum Troubleshooting
    Last Post: 28th January 2011, 23:48
  3. Washers not working
    By Padster72 in forum Bodywork & Interior
    Last Post: 14th June 2010, 20:57
  4. Washers stopped working
    By Marky in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2009, 16:22
  5. washers are working weheyeeee
    By andy.l in forum Vectra C / Signum Car Chat
    Last Post: 8th September 2006, 21:00
