Thread: lumpy idle on a 2.2(z22se)
    Regular Member denzilbud's Avatar
    cambridge
    Default lumpy idle on a 2.2(z22se)
    as title in the morning when i first start the car it has a real lumpy idle,and the only way i can stop it is to rev the engine for a couple of mins,could someone please tell me if the 3rd injector problem relates to my engine or not, also what could be the cause of this i have cleaned the throttle body and egr,also the car feels sluggish when under load cheers in advance.
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Hi mate the 3rd injector relates to the Diesel 1.9 not yours try cleaning throttle body
    cambridge
    could it be anything else as ive done the tb and egr
    Apr 2008
    Liverpool
    Quote Originally Posted by denzilbud View Post
    Hmm Well one thing I done what seemed to smooth out the idle was when you took off the throttle body Did you have a look down in to the Intake Manifold?
    When I took my TB off the intake manifold was covered in a black tar like substance took me a while to clean it out but done it all and it ran a lot better
    Other then that have you tried injector cleaner?
    cambridge
    hi mate didnt clean intake how did you clean yours,yes i put some redex in with a full tank when i first bought the car will give it another go as havent done it in a while,could the problem have anything to do with plugs or coil pack?
    Apr 2008
    Liverpool
    I have heard of the 2.2 Direct Z22YH having problems with the Coilpack I would say just check your plugs first as its only a 5 min jobby could be your sparkers.
    to clean the Intake manifold I just took off the throttle body and the hole that was left there I sprayed carb cleaner to loosen it all up then put a cloth down there tied to a stick as my arms are not thin enough and just swobbed it all up.
    I gave it a good clean took my time but was worth it
    cambridge
    cheers mate will give it a try
  1. Z22SE Lumpy Idle
    By Lean6 in forum Engine & Drivetrain
    Last Post: 27th August 2012, 11:54
  2. 2.0t edition 100 lumpy idle
    By 6009tristanb in forum Engine & Drivetrain
    Last Post: 4th January 2012, 17:02
  3. Lumpy idle on 2.2 Direct SRi
    By Palmo in forum Engine & Drivetrain
    Last Post: 22nd January 2009, 18:53
  4. lumpy idle
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2008, 20:39
  5. 3.2 v6 Lumpy idle!?!
    By byebyeitsagsi in forum Engine & Drivetrain
    Last Post: 13th August 2008, 12:24
z22se idle problem
