Thread: 2003 Vectra 2.0 DTI - Error Code P0234 - Boost pressure Control positive deviation
    Jul 2009
    King Lynn
    Default 2003 Vectra 2.0 DTI - Error Code P0234 - Boost pressure Control positive deviation
    Hello All,
    I bought a 2nd hand vectra last week.. Which I was really happy about. But sadly on my way back home the car went in to limp mode. The usual Car and spanner icon, couldnt rev beyond 3000 and turbo wasnt spinning. Also the brake pad warning came on but it was expected since the seller said it needs replacing. I then took the car to a local garage to find the error code. It was P0234 - Boost pressure Control positive deviation and possible resolutions were Hose Connection, wiring, TC wastegate regulator valve, TC Wastegate....Since there are number of possibilities here, would any one know what is the most common cause for this kind of fault? How much would it cost to fix it? Thanks in advance...
    Remove the boost sensor and give it a clean. Also check all the hoses for possible leaks - boost hoses.
    The DTi's tend to soot the sensors up
    East Midlands
    Have a look at this thread might help you... The red arrow indicates a split in the nearside boost hose which was my problem ..check yours.
    http://www.vectra-c.com/forum/showthread.php?t=75475
    Apr 2009
    liverpool
    I'm betting on the hose too. It will only be a tiny hole/split. Mine went with exactly those symptoms. Turned out to be the top hose, although on my car (2.2DTI) you have to buy the complete assmbly, 85 quid. If you found you could get out of limp mode by switching off/on, but that it came back on throttle, then that's possibly it. Parts department guy sounded like he spent all day selling these.......
    Jul 2009
    King Lynn
    Smile Found the problem
    I had another look today at the pipes and found the split.. Fixed it temporarily and got the turbo back.. Thank you every one for your help.
    The split pipe circled in red. (Found near the battery)
    Attachment 24268
    Near Battery, the connector circled in green was unplugged and doenst seem to fit anywhere....There seems to be something missing where the second green circle is.
    Im not too worried about it as every thing is working fine but would be nice to know where that thing goes?
    lanarkshire
    why not just wrap amalgum tape around split hose ?
    East Midlands
    Quote Originally Posted by 53Vectra2DTI View Post
    Attachment 24268
    My 2.0dti ,the pipe you mention,mine went in exactly the same place and right hand side hose was split,so taped it up using duct tape no problem since been on for 2 months and its stopping on till i sell it,bearing in mind they'r 60 odd squid a throw for a bit of pipe"outrageous
  1. Fault Code P0234 - Boost Pressue
    By Gazz in forum Engine & Drivetrain
    Last Post: 15th October 2012, 10:48
  2. P0234 Error Code Definition
    By viper8 in forum Engine & Drivetrain
    Last Post: 31st December 2011, 14:10
  3. P0234 Error code.
    By ectraz in forum Electrical & ICE (including SatNav)
    Last Post: 23rd September 2011, 20:23
  4. Replies: 7
    Last Post: 22nd August 2011, 14:41
  5. error code P0234 - Boost pressure control
    By duncanm in forum Engine & Drivetrain
    Last Post: 4th May 2011, 17:24
vectra c 2.0dti boost pressure control positive deviation
opel vectra 2.0 dti p0300 positive
p0234 opel zafira 2.0 dti
vauxhall vectra p0234
Vauxhall P0234
vauxhall 2.2 dti fault code p0234
p0234 code vauxhall vectra 2.0 dti 2005
p0234 vauxhall zafira
2.0 dti p0234
p0234 boost pressure control positive deviation
Опель зафира 2.2 дизель 2003 ошибка р0234
p0234 2.0 dti
opel vectra c boost presure reguliation
p0234 y20dth
vectra c p0234
vectra c z19.dth p0234
opel p0234 2.0
opel zafira 2.2 dti fault code p0234
symptoms of split boost pipe vectra c dti
zafira dti boost control deviation
zafira 2.0 dti p0234
2.0dti p0234
p0234 Boost pressure regulation positive deviation Intermittent
p0234 vauxhall vectra
opel signum 2 0 dth p0234
