Thread: Exhaust problems :(
    Regular Member sirnapper's Avatar
    Ldon
    Default Exhaust problems :(
    Hello there, when i had my car last serviced the mechanic told me there was a crack on the flexi joint with comes after the cat. He showed me and there was black coot where the gases were escaping. Now about a day back i can would hear a sound which sounds like i have a hole in the exhaust and ratteling sound. Ive also got the emmision light on and car is frequently going into limp mode. Ive got the car for diagnosis on wednesday so just wondering can a cracked flexi joint cause emmision light and limp mode ?
    Ldon
    bump
    May 2008
    Tyneside
    Theres an O2 sensor before and after the cat, so yes if there is a leak in the exhaust before this second sensor it will throw up a fault code. HTH
    Ldon
    ooo ic and do the diesel pump and water pump make a racket if they are on the way out?
  1. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  2. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  3. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
  4. magnex cat back exhaust problems
    By Morephun in forum Engine & Drivetrain
    Last Post: 24th June 2009, 17:49
  5. Irmscher Quad exhaust fitting problems 2.8T Elite
    By Clint H in forum Petrol Engine related
    Last Post: 3rd January 2009, 22:43
