has anyone upgraded normal headlight bulbs? and what to?
mine are rather on the rubbish side ive decided!
hi m8
well known on here that they are crap
you got several choices m8
new bulbs which most go for osram nightbreakers or phillips bluevision.
or the biggy which is go for the HIDs
does this help
mark
yeah cheers mate, so if i pop up to halfrauds tomorrow they should have something?
what wattage am i aiming at?
haha, so what do most people go for then
cheers mate il have a look around
You *might* improve the lights by doing Duncan's suggested advice of raising the low beam setting slightly.
Tried searching for his post, but damned if I can find the link.
EDIT - finally found it:- http://www.vectra-c.com/forum/showthread.php?t=33655
This also worked on my facelift, so it's not just a fix for pre-facelift Vectra's.
There is nothing wrong with the lamps, it just the way they are setup; compare dip and main beam
Usual solution is to replace the bulbs, but this usually only increases the illumination on dip and has little effect on main beam
Another consideration is asking your local MoT station to realign the lamps to the highest legally correct setting
I've done this on both of my Vectras and have this performed a few days after taking ownership
One final point is I have noticed the latest E bulbs have a dreadful green tint in them
Philips Vision Plus is my recommendation, dip AND main beam
