Results 1 to 10 of 13
Thread: flickering flashing dash and headlights
    london
    Default flickering flashing dash and headlights
    hi just noticed today that while driving my car in the day my dash lights were flickering while reving the car
    then at night i noticed that my headlights were also flickering
    could this be an alternator problem
    thanks
    Regular Member poves's Avatar
    lancashire
    Maybe , check your battery terminals are not loose as well.
    11 Post(s)
    Was it only doing it when you turned the steering wheel?
    If so, then nothing is wrong. The electric PAS pump draws a lot of juice from the electrical system.
    london
    checked battery terminals they are tight
    its doing it all the time even when stationary
    Regular Member mikesri2.2's Avatar
    Jun 2009
    cheshire
    have got the same problem been to the garage 3 times
    dont think there is a fix
    just a design fault i think
    the is a old post some where on the forum mate might help you
    london
    FIXED
    it was the 13mm high tension charging connection on the back of the alternator
    i had to disconnect it then sand it with wet and dry the reconnect
    now no flickering lights at all even when steering
    also it has fixed a problem i had with juddering engine at low revs which seemed like a misfire thought it was egr that i had recently cleaned now it runs fine
    saved me a small fortune for 10mins work and a piece of sand paper
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    result nice one
    11 Post(s)
    Quote Originally Posted by in7ox View Post
    Did you put some petrolium jelly, or some other electrical protectant on the terminals afterwards to prevent future corrosion?
    london
    no m8 but thanks for the tip
    May try this fix as my display pulses .. could be my 'Animal Magnetism' ....
  1. Flickering headlights
    By Mrpam in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2013, 23:12
  2. Flickering Headlights
    By erni3wi5e in forum Bodywork & Interior
    Last Post: 9th March 2012, 16:57
  3. Headlights flickering ???
    By digitalinkjetman in forum Electrical & ICE (including SatNav)
    Last Post: 3rd November 2011, 11:49
  4. Flashing/Flickering HID Fog-lights
    By Damo77 in forum Styling
    Last Post: 24th March 2011, 11:50
  5. Headlights flickering
    By troutybrown in forum Electrical & ICE (including SatNav)
    Last Post: 3rd January 2011, 19:46
