Thread: squeaky rear o/s brake, 1.9 150ps 07 reg
    Regular Member mitch's Avatar
    WIGSTON, LEICESTER, LE18
    Default squeaky rear o/s brake, 1.9 150ps 07 reg
    hi got this problem as above when first drive the car but after about 5 mins it goes away. the brake disc looks a bit rusty and worn too, and differs from the other side, the car had its 2nd service a few months ago and it was ok before this, the car has done 19,000 miles now. is this owt to worry about or should i get intouch with vxh?? its so annoying. has anyone had the same trouble and what was the out come?
    would this be a warranty job?? please look at the photo of disc what do you folk reckon
    Attachment 24176
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi Bud
    looks like you have a calliper thats starting to sieze on piston needs pulling down and cleaning,and building with copper slip.vx won't cover under warranty on 07 as brakes are a normal wear part
    hi is this a big job as only use to doing d,i,y jobs on bangers
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    you will need a rewind tool mitch, my off side rear calliper was sticking a while ago but after a stripdown and a good clean it now seem's to be ok, i also fitted new disk's and pad's
    hth
    Midlands Mod Shop - NFFC.
    new discs,will it need them that sounds expensive, think ill just clean em up and copper grease pads, how much is a rewind tool mate??
    Trim : Get a
    i got disk's and pad kit from VX for less then £60.00 trade and my mate had the rewind tool, the tool's are on ebay without the adaptor for the vec for iirc around £20.00 no idea on the price of the adaptor though.....
    Regular Member sparky71a's Avatar
    Apr 2006
    At the Garage
    Your callipers need copper greasing mate,probably nowt more than that,your local will do that for a few quid,if you've got a regular mechanic.
    Either that or take the wheel off and do it yourself,ten minute job.
    Jul 2009
    Engine : 20 Dti
    Hi Mitch there's more too it than a ten minute job 'but looking at the foto your disc looks fine,
  1. Difference between 120 ps and 150ps?
    By Bren G in forum Diesel Engine related
    Last Post: 22nd September 2012, 21:50
  2. squeaky rear end
    By porthy-t in forum Suspension, Wheels & Brakes
    Last Post: 17th October 2009, 06:37
  3. squeaky rear - a new noise to discuss
    By Agoogy in forum Suspension, Wheels & Brakes
    Last Post: 7th March 2009, 19:59
  4. Squeaky rear end!
    Last Post: 18th October 2008, 01:46
  5. Squeaky Rear
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2008, 20:28
squeaky rear breakes vectra. c
