hi, i have for sale a SPECIALIZED ROCKHOPPER PRO DISC 2003 MODEL details are below. ive had it about 4 years but its not had that much use. looking for about 400 pounds. i also have a CANNONDALE R600 2004 model, again details below. bought this at the same time for the mrs who then found out she was pregnant. its been used about 5 times so is still in perfect condition.
looking for around 500 pounds. i am seling these items elsewhere but please feel free to ask any questions.
thanks
Rockhopper Pro Disc
FeaturesTechnical SpecificationsGeometryCheck out the custom lockout on this Manitou Axel Super fork with an alloy steerer and 80mm of coil-sprung, adjustable rebound travel.
Race worthy specs like Shimano Ocatlink BB, LX rear derailleur, Mavic 221 rims.
Disc brakes for unparalleled stopping power.
A true performance frame, the A1 Premium Aluminum chassis features a double butted front triangle, disc mounts and a replaceable derailleur hanger.
Body Geometry saddle provide comfort for those long days in the saddle.
FRAMEA1 Premium Aluminum, double butted front triangle, disc only, replaceable derailleur hanger, rack eyeletsFORKManitou Axel Super, 80mm travel, coil spring, external rebound adj., custom lockout lever, disc only, alloy steererHEADSET1 1/8" threadless, black steel cups, loose ball bearings w/ sealsSTEMAluminum, 10 degree rise, TIG welded, blackHANDLEBARSSpecialized XC Low Rise bar, 6066 Alloy, 6 degree upsweep, 8 degree backsweep, 640mm width TAPE / GRIPSSpecialized MTB grip, black, double density KratonFRONT BRAKEShimano M-525 full hydraulic disc, resin pads, 6" rotorREAR BRAKEShimano M-525 full hydraulic disc, resin pads, 6" rotorBRAKE LEVERSShimano M-525 full hydraulic discFRONT DERAILLEURShimano M-510 Deore, 34.9mm clamp, bottom pullREAR DERAILLEURShimano M-570 LXSHIFT LEVERSShimano M-510 DeoreCASSETTEShimano HG-50 LX, 9 speed, 11x34tCHAINShimano HG-73CRANKSETSpecialized Strongarm II, XT SplineCHAINRINGS44Ax32Sx22S, 7050 alloy 3mm thick outer ring, 4 bolt, 104/64mm pattern, steel chainring boltsBOTTOM BRACKETShimano ES-30 Octalink spline, 68mm shell, 113mm spindlePEDALSShimano 505 SPDRIMSMavic X223 disc, 26", black, eyeletsFRONT HUBSpecialized Stout Disc, 32 hole, cartridge bearings, 9mm SkraxleREAR HUBShimano M-525 Disc, 32 hole, loose ball bearings, alloy Q/RSPOKES1.8mm (15g) black stainless, brass nipples, L260/R263mm front, L261/R260mm rearFRONT TIRESpecialized Roll-X 26 x 2.0", aramid beadREAR TIRESpecialized Roll-X 26 x 2.0", aramid beadTUBESSpecialized Ultralight, presta valveSADDLESpecialized Body Geometry technology, hollow Cr-Mo railsSEAT POST2014 Alloy, black, 30.9 x 350/400mmSEAT BINDERAlloy collar with Q/R, 34.9mm clamp I.D., blackNOTESChain stay/seat stay protector, derailleur protector, reflectors,
this is a link to bikepedia which has the spec of the racer
