Thread: How hot should I be running?
    Oct 2007
    Scotland
    Default How hot should I be running?
    1.9 CDTI 150 and I noticed today on a 100 mile round trip on A and B class roads that the temperature gauge didnt go above 80. In fact it sat the whole time around 75. I thought this was pretty low cos it usually sits between 85 - 90. What could be causing it to suddenly sit so low on a spirited drive? Outside temp was 15 degrees C.
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    mine always sits about 70-80 and only gets more if sitting in traffic and a roasting day
    Wales, UK
    About the same as mine to be honest !
    Jul 2009
    sussex
    80 ish is ideal
    dont forget the gauge isnt dead accurate anyway
    diesels dont run as hot as petrols either, worth bearing in mind.
    Rochford
    Mine used to sit around 75-80 and I didn't think this was hot enough so I changed the thermostat and now it always heats up to 87 and sitting in traffic or driving it hard it increases. But when its warmed up it never goes below 87. The only downside of changing it was the cost. From memory it cost me around £48 as you have to buy the complete housing, as its all one piece.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    my signum 20dti has allways run at 80/85 and as jon says all sensors and gauges are not all same
    Regular Member barkzz's Avatar
    80-90 for me, depending on use, and the weather.
    Perfectlyt normal
    May 2006
    scotland
    My CDTI used to be pretty steady at 80ish but now its anywhere between 75 to 85. I think it maybe a time for a change of stat. Damm, I thought it was just a quick trip to halfrauds and a fiver but from above, apparently not. Is it an easy change (anyone) and do you have to drain the entire coolent system?
    thanks.
    Southampton
    Just had my thermostat changed - was maxing at 78 on the motorway, but would go go 90 in town. Now sitting at 88 on the motorway and in town which is consitent and where it used to be when I first had the car.
    (and the Collant temp doesn't report -20C anymore which is a bonus!)
    Rochford
    Its a bit fiddly as there are lots of pipes connected in a small area. If your competent with a spanner then you should have no problems. I used about 2 bottles of coolant.
  1. Anyone running LPG?
    By forde in forum Vectra C / Signum Car Chat
    Last Post: 21st November 2012, 08:55
  2. Running on oil
    By dunkymunky in forum Diesel Engine related
    Last Post: 18th November 2010, 08:34
  3. anyone running this box
    By Keithy in forum Tuning
    Last Post: 28th December 2009, 23:18
  4. Running in?
    By Messenger in forum Engine & Drivetrain
    Last Post: 30th January 2009, 11:56
  5. running much better
    By monty1 in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2007, 21:55
