Results 1 to 10 of 18
Thread: Horrid FLAT SPOT between 1-2k RPM.HELP!
    Birmingham
    Default Horrid FLAT SPOT between 1-2k RPM.HELP!
    Chaps,
    This is an ongoing problem im trying to resolve with my dad's CDTI 150 SRI. I have repalced the EGR valve for a second hand unit which has apparently been re-worked by Vx (has a hole in the solenoid side), and I have previously cleaned the old EGR Valve and the inlet manifold and boost sensor.
    The EGR valve, Boost Sensor and Swirl valve have all been repalced by Vx 2 years ago and the car is only just touching 27k from new (55/2005).
    I have also checked the swirl bar and it is happily spinning all 4 injector's when rev'd.....
    ............the problem I am getting is a horrible horrible flat spot between 1-2k RPM. It just doesnt seem to want to shift or is very relucatant, but once im over 2k RPM, its right as rain!
    I had the same'ish problem with the old EGR Valve and same with this, everything else seems in order too.....what next?
    THIS ONLY happens during take off.....if I take off an rev over 2k RPM, its good and much better, but anything below and I feel a HUGE LAG!!
    Its a bit as when im at the lights, I almost get the feeling that the chap next to me in a 1 litre Micra Tempest is going embarass me, OR he thinks I want to race him.
    It feels a though it will stall if it dont get some proper high rev'ing!
    Bye bye Vec B
    - Hello Siggy!
    Birmingham
    Bye bye Vec B
    - Hello Siggy!
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I have a similar issue with my V6 and some have suggested it could be a faulty air flow sensor...hmmm
    Feb 2007
    North west
    sounds like a dirty EGR valve to me. have you cleaned it ?
    Regular Member slick91's Avatar
    Jul 2009
    Newcastle
    Quote Originally Posted by rob 2.2dti View Post
    hhhmmmm .......[/quote]The EGR valve, Boost Sensor and Swirl valve have all been repalced by Vx 2 years ago and the car is only just touching 27k from new (55/2005).
    think so mate.......
    Birmingham
    Quote Originally Posted by slick91 View Post
    hhhmmmm .......
    think so mate.......[/quote]
    Deffo not this folks....I CLEANED THE EGR valve out myself two weeks and have just replaced it for another 2nd hand unit too which is clean as a whistle too and I double cleaned it to make 100% sure!
    Bye bye Vec B
    - Hello Siggy!
    Full Member Big Sig's Avatar
    Variable turbo vanes stuck?
    Birmingham
    :thud: !
    OK, now I am proper proper confused.
    are Variable turbo vanes ??
    Bye bye Vec B
    - Hello Siggy!
    The turbo changes the inlet size with the variable vanes to provide constant boost over a longer rev range. They can become full of rubbish and stick in one place, therefor acting like turbos of old. Loads of lag until they spool up.
    I think <- my disclaimer!
    BTW, K&N forsale in the forsale section
    Aug 2009
    BIRMINGHAM
    hi mate
    how you doing iv'e just got myself a 58 plate 1.8 sri and i have the same lag when from 1st to 2nd thinking of taking it back to VX to see if they can sort it out
  1. Flat spot :(
    By marc vectra sri in forum Vectra C / Signum Troubleshooting
    Last Post: 13th August 2012, 19:06
  2. 1.8 flat spot...
    By danBoy in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2009, 09:25
  3. Flat spot!
    By bigknill in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2009, 09:43
  4. flat spot
    By surreyl31 in forum Petrol Engine related
    Last Post: 16th July 2007, 18:41
  5. Flat spot
    By mriley60 in forum Engine & Drivetrain
    Last Post: 3rd July 2007, 14:15
