Thread: Check right parking light
    hinckley
    Default Check right parking light
    I've had my car vec for about 2 months now and this message has appeared a few times when the lights aren't on. If you turn the lights on to check then the indicator on the same side is stuck on solid and the side light or parking light isn't, give the headlamp a whack and the sidelight comes on and the indicator goes out and the message clears. Do you think this is a wiring fault?
    thanks
    Ian
    Surrey
    Loose connection.
    hinckley
    would that cause the indicator to be on solid?
    I'm surprised it comes up "Check right parking light", on mine it is just "Check parking light"
    I would suggest changing all four front bulbs, indicator and side light, then see what happens
    The side lights warning comes up on mine usually once every 3 months, but a light tap on the relevant headlamp and the bulb comes back on
    hinckley
    you've never had the indicator come on and stay even when it isn't powered?
    hinckley
    i wonder if the car transfer the power from the sidelight to the indicator as a saftey thing as it does when you have a brake light or tail light fail?
    11 Post(s)
    Quote Originally Posted by ian mc View Post
    Correct.
    No, only when the key out of the ignition and indictor stalk is set to overnight parking mode
    However, even then only the front sidelight and rear warning light come on, never an indicator
    Regular Member Swaite53's Avatar
    South Wales
    On my pre-facelift, when a sidelight bulb goes, the indicator lights up in place. It does also say which side of the car has the problem.
    It's possibly a bad earth. You could try taking out the bulb and giving the contact a clean and replacing it. I had an intermittent problem, with the bulb working one minute, then not the next. I cleaned the contact and all was good after that.
    hinckley
    i Will do that, thanks everybody for your help
  1. Parking light, check left
    By SlowCoach in forum Electrical & ICE (including SatNav)
    Last Post: 21st October 2012, 09:00
  2. Check parking light?
    By krazylegz in forum Vectra C / Signum Car Chat
    Last Post: 26th March 2012, 15:19
  3. Parking light/side light
    By mc_orion in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2009, 11:14
  4. Parking light check bulb light on and wont go off
    By rollercoaster63 in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2008, 12:03
  5. Check right parking light.....
    By ROB WOODHOUSE in forum Electrical & ICE (including SatNav)
    Last Post: 16th November 2006, 23:39
check right parking light
check right parking light opelvectra c check parking light co tocheck right rear parking light insigniaparking light check right opel
