Results 1 to 10 of 13
Thread: can somebody do a how 2 on fitting insignia washer jets
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Default can somebody do a how 2 on fitting insignia washer jets
    was wondering the above have had a look with the search button but can only find how to adjust them.
    having problems removing the skuttle trim under the screen
    do the old jets just push out from this or are they held in by clips as mine dont seem to want to budge
    Regular Member MattW's Avatar
    Sheffield
    The old ones just push out from the trim.
    You don't actually need to remove the trim, just remove the rubber edging, and it will lift up enough to access them (as there is a flap where the pollen filter goes).
    New ones just push back in.
    Took me 10 minutes in the rain the other day.
    the pipework is a little on the tight side but ok once the small over piece is pulled back hth ......
    Regular Member VECTRA HEAD's Avatar
    Derry
    Could someone please tell me what is the difference with the insigna washer jets and the vectra jets?
    Quote Originally Posted by VECTRA HEAD View Post
    Try the search button it is your friend ...............
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    instead of the 2 "lines" of washer fluid on the screen from each washer. it makes a fine spray on the hole windscreen.
    Mileage : 000
    I belive the water sort of comes out in a fan pattern ( a bit like a jet washer) rather than just a jet.
    Derry
    thanks guys
    Wales, UK
    Do a search on youtube for insgnia jet, I think there is an Astra VXR with them and they look really good !!
    Full Member tubby's Avatar
    May 2007
    Norwich
    Vehicle : Vectra sri
    Engine : 2.2 z22se
    Ive just ordered a set from the stealers for 1.85 each!!!Get in there
  1. insignia washer jets
    By rozzer2006 in forum Styling
    Last Post: 29th January 2013, 14:58
  2. insignia washer jets
    By brod999 in forum General Motoring Chat
    Last Post: 31st December 2012, 15:30
  3. Insignia Washer Jets
    By 11mallard in forum General Chat
    Last Post: 28th May 2012, 19:55
  4. Insignia washer jets
    By fester999 in forum Vectra C / Signum Car Chat
    Last Post: 21st August 2011, 23:24
  5. Insignia Washer Jets
    By simmo3187 in forum Styling
    Last Post: 28th February 2011, 20:19
