Thread: Coolant loss
    Hartlepool
    Default Coolant loss
    Hi guys what in your humble opinion are the main reasons for coolant loss?
    The facts
    1) lose more when on longer journeys
    2) no apparant sign of leaks
    3) Temperature gauge reading normal
    4) Only indication of anything wrong is the radiator symbol
    5) Used the supposedly more potent version of radweld and that hasn't worked either (totally lost now)
    Have booked it in to the garage for a pressure test sems its the only way to go I am dreading it
    Thanks in advance boys
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    i.d say centre seal on the waterpump
    May 2008
    Tyneside
    Was losing coolant but there was a tell tale residue on the seam of the coolant header tank. New tank sorted problem, only £17 from the dealers which included the level switch. Don't know if tank splitting on the seam is a common problem with the vectra.
    Regular Member Swaite53's Avatar
    South Wales
    It could be the header tank cap. They have a habbit not sealing the system very well.
    I find my local dealer doesn't tighten it up properly after a service, which causes the coolant to evaporate. Make sure the cap is completely tight.
    If I forget to re-tighten it after a service, mine will loses coolant, but is fine if I tighten it.
    Hartlepool
    I have replaced the filler cap and it is well tight and cant see any tell tale signs of leakage so it looks like its gonna be expensive again ****** sick of cars lol
    Hartlepool
    forgot to say that when I go to top the water/antifreeze up there is very little or no pressure when i loosen the cap! weather this is significant i dont know
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I'm in the same situation as you mate. My V6DTi has lost some coolant in 3 months, about a cm under the marking I made in April. No apparent leaks on the driveway, but I haven't seen the coolant light on so far. Temperature guage is reading normal.
    I'm totally lost
    Hartlepool
    bit worse for me Celes i'm losing about 200ml on a 60 mile run which is bad i think
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by monkeyhinger View Post
    Have you had the engine opened yet? Better check the headgasket
  1. Coolant loss.
    By BigWilko in forum Y & Z30DT Specific
    Last Post: 10th January 2013, 21:18
  2. V6 Coolant loss, Help!
    By v6boy in forum Vectra C / Signum Troubleshooting
    Last Post: 12th September 2010, 16:01
  3. Gsi coolant loss
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2010, 15:13
  4. Coolant Loss
    By george in forum Engine & Drivetrain
    Last Post: 12th April 2007, 06:39
  5. 1.8 coolant + oil loss
    By Aleco in forum Engine & Drivetrain
    Last Post: 15th March 2007, 21:52
