Results 1 to 10 of 13
Thread: Spark Plugs
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    confused Spark Plugs
    ok, heres a couple of questions.
    i just fitted the bosch super 4 spark plugs to my 2004 1.8 LS. started it & all seemed ok, untill it started running lumpy at idle & when revving the engine there was ALOT of hesitation. i also noticed the orange engine symbol was lit (NOT flashing) on the dash.
    so, i disconnected the battery & left it for an hour or so while i did something else. reconnected the battery & still the same.
    then i decided to replace the original spark plugs. started the engine & it seems to not run lumpy, but the orange engine symbol is still lit.
    i tried the instructions on the how to to get any fault codes & got 0301 which equates to a misfire on cylinder 1.
    my questions are, which is cylinder 1 & what could the cause & solution to the problem be?
    Mileage : 000
    Cylinder #1 is normaly the one at the cambelt end of the engine.
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    ok, cheers, thats a start. unfortunately i didnt get the code before i changed the plugs back to to originals, so they may be ok, im guessing it may be the coil pack thats at fault
    Mileage : 000
    I did have to replace the coil pack on my wifes Vectra B. That give a sort of misfire, abit like a "duff" spark plug lead.
    Regular Member Swaite53's Avatar
    South Wales
    If I've read correctly, are you saying that now you've changed back to your original plugs, and the engine runs fine, but the warning light is still lit?
    Was the car running fine before changing the plugs?
    It may be worth disconnecting the battery again, while leaving your original plugs in. It could be the old code it was reporting with the new plugs, and not a problem on the car.
    I recently had a misfire on cylinder 1 and the emission light was lit, and the problem was the ignition module (my own fault for washing the engine and not covering it up properly).
    It could just be that one of the new plugs are faulty, or maybe incompatible.
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    yes you are correct on all counts. ive been driving it for 2 days & no sign of any misfire, just the orange engine light on the dash being lit.
    i will have a go at disconnecting the battery again & see if that clears the light. bit annoyed if its 1 new plug thats faulty!
    i will update later on.
    if anyone else has any ideas, i would be very grateful to hear them.
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    right, quick update.
    had driven the car for a couple of days with the orange engine symbol illuminated. went out sunday lunchtime, light still on. didnt drive it again until monday evening, so over 24 hours, and hey presto, no engine light on! i didnt even have to disconnect the battery! weird!
    so, my next question is, are the new spark plugs i fitted the correct ones? they are the Bosch Super 4 FR91X 0242222505. anyone any ideas? i got them from fleabay, the seller said they were the correct ones, have my doubts now!
    South Wales
    I believe that the warning lights will go out after about 10 engine starts if is not currently recording a fault (which means that whatever the fault was, has gone [at the moment]).
    The light that you had on sounds like the emissions light, which will illuminate if the sensor thinks the car's emissions may be too high.
    Whatever the problem is, it's almost certainly related to the Super 4 spark plugs, seeing as it was fine before, and now fine since you have taken them out.
    Did you set the gap on the spark plugs?
    If the spark plugs were incorrectly gapped, or the wrong type, it may not be burning the fuel as efficiently as it should, which could cause the problem you described.
    The 'standard' plugs required for the 1.8 are Bosch FQR 8 LEU2 with a gap of 1.35 mm. I don't know what the spec would be for a super 4 plug. Halfords may have a comparison chart, or you could email this company:
    http://www.powersparks.co.uk/boschorderpage.htm
    Hope to help.
    PS. I put these on a 1994 Astra years ago, and I really didn't notice any difference at all. It was only the 1.4 (60bhp), so it didn't have anything to start with - maybe it makes more of a difference on a more powerful engine.
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    bump
    Feb 2007
    North west
    sounds like a plug problem to me, I've cracked the ceramic part when fitting new plugs and got this reaction. Check each plug carefully, its easily done. EM lights can disappear on their own if the fault has cleared. The code will still be stored but no light illuminated. The other possibility would be a loose HT lead on one plug when you fitted the new set, could still give a misfire.
  1. 3.2v6 best spark plugs to get?
    By PANDY 3.2 V6 in forum Petrol Engine related
    Last Post: 14th February 2012, 02:15
  2. Spark plugs 2.0T?
    By Steven in forum Petrol Engine related
    Last Post: 24th September 2011, 16:43
  3. Spark plugs
    By telstar in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2010, 20:36
  4. spark plugs
    By Morephun in forum Engine & Drivetrain
    Last Post: 1st October 2008, 06:37
  5. Spark plugs for LPG
    By Gavin1977 in forum Engine & Drivetrain
    Last Post: 3rd December 2007, 09:17
