Thread: overheating
    Jul 2009
    milton keynes
    Default overheating
    Hi i have a vectra c 1.8 sxi and it keeps overheating any throughts please
    Mileage : 000
    Might be an air lock in the cooling system?.
    newcastle upon tyne
    Is the fan cutting in when it should?
    Regular Member Swaite53's Avatar
    South Wales
    Just a thought!
    Have you got sufficient coolant and at the right mixture?
    The tank may have been topped up with water alone, over the years, and even if the tank is at the right level, the mixture may be too weak.
    Full Member Big Sig's Avatar
    Z18XE? Thermostat
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi Jonesey is the engine over heating or are you just getting an overheating reading on your temp guage.are you having to top up coolant.
    Jul 2009
    milton keynes
    Default Thermostat
    Z18XE? Thermostat
    hi i have replaced this and still have the same problem
    Regular Member jimmyred's Avatar
    Dec 2010
    Southport
    how much are you overheating by? At 92C the fan should kick in taking temp back down to 86-87C. My car will often hit 92C in traffic but once on open road cools again. If its getting higher than this perhaps fan isn't doing its job properly.
  1. Overheating
    By Steve1974 in forum Engine & Drivetrain
    Last Post: 6th May 2013, 13:52
  2. Cdti 150 overheating
    By WHOOSH05 in forum Engine & Drivetrain
    Last Post: 29th August 2011, 11:43
  3. Overheating or not ???
    By Grahamy in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2011, 19:22
  4. overheating/no hot air!?
    By P-Mutton2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 21st November 2009, 11:54
  5. Car Overheating !!!
    By andythilo in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2009, 17:56
overheating problem with vectra c 1.8
vectra c 1.8 engine overheating
vauxhall vectra 1.8 overheating
