Thread: EGR Valve-hole in solenoid side
    Birmingham
    Default EGR Valve-hole in solenoid side
    Guy's, I have just got my used and Vx re-worked EGR Valve, and the solenoid side has the hole in it.....does this need to be closed/blanked off before fitting or am I OK to roll with it?
    Bye bye Vec B
    - Hello Siggy!
    Ashington, Northumberland
    No its fine mate. the hole would have been drilled in order to insert a punch to lightly tap out the piston assembly inside for cleaning. It's fine how it is and the hole is already there for when you need to clkean it out again
    If it makes you feel any easier, you could put a bit of silicon over it to cover it but it won't take any harm if you don't
    Jul 2009
    manchester
    HI By vx reworked i presume this is a refurbished item from any dealer if so how much was it, as i think my egr is in the early stages of clogging up.
    Birmingham
    Quote Originally Posted by GARY3306 View Post
    Dont I know it mate....!!
    Quote Originally Posted by msvectra View Post
    Well, that is a very good question MS......it is a second had unit-thats for sure....as to whether or not Vx have re-worked it remains unknown. Its an ebay Item so you LIVE IN HOPE I guess!
    Bye bye Vec B
    - Hello Siggy!
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    sounds like maybe VX have been reading our how2's...
    Quote Originally Posted by lofty View Post
    sounds like maybe vx have been reading our how2's... :d
    pmsl
    Birmingham
    About frigging time if you ask me!
    Bye bye Vec B
    - Hello Siggy!
  1. Vectra C DTI missing solenoid valve? (EGR/Swirl flaps)
    By Deacs in forum Engine & Drivetrain
    Last Post: 22nd August 2012, 11:18
  2. Pulse Ratio Boost Pressure Solenoid Valve
    By iwtand in forum Y & Z30DT Specific
    Last Post: 12th March 2012, 19:57
  3. Throttle valve solenoid question!!
    By the_riddler in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2012, 22:20
  4. Vacuum solenoid valve
    By ed taylor in forum General Chat
    Last Post: 3rd March 2007, 21:27
