Thread: Thinking of buying a 3.0 CDTI auto elite estate - your thoughts please
    Jul 2009
    Bracknell, Berks
    Thumbs up Thinking of buying a 3.0 CDTI auto elite estate - your thoughts please
    Firstly hello. I have become a member since I am looking to buy a vectra C.
    The title says it all really, but I would like some honest opinions. I am looking for a facelift model and really need to know any pitfalls or areas that I should be paying attention to when buying. What sort of price should I be looking to pay for a them etc etc. It is to replace a 1.8 Astra G SRi which is the other halfs.
    Thanks in advance
    Regular Member r.bailey63's Avatar
    Mar 2007
    Stockton on Tees
    I have a 2003 SRI 3.0 CDTI Auto, it has been really great car until it turned 100k, then had a few engine trouble and ESP problems, Auto box seems bullet proof though. Best advice would be to buy one with as low as mileage as possible. I will definatley be having another one!
    Go the VX website
    Look at what trade-in prices are
    Then go to Network Q and see what is available
    Sadly 3.0 V6 CDTI models are rare
    Prices should be depressed as it was not a very attractive company car due to the high tax level and relatively mow MPG, but the engines are bomb-proof (compared to the 1.9 CDTI)
    For those reasons prices are typically 5-10% above those for a 1.9 CDTI
    Check service history
    With the key out of the ignition, press the mileomter and see what happens
    If a spanner and number appears, then the car is on ECOFlex servicing, and this is the mileage TO next service
    Depending on year, it will be either 20K or 30K mile service intervals
    Check that against the service book
    Check front and rear brakes
    Check all tyres
    Front brake pads last about 25K miles, you can get three sets of pads to discs, but only just!
    Rear brake pads and discs last about 30K miles, for this reason there is no point replacing just the pads as the discs won't be far behind
    Run the engine for about 5 minutes, or until the temperature needle moves, then switch off
    Check the oil level
    The oil should be almost like water, VERY runny
    General electrical gremlins, pretty much the same as any other Vectra C, such as SAS (steering angle) or CIM module failure
    The only problem I had with the engine was very minor oil leak, the sump seal had failed just a few days after the second service
    Finally, tyres
    Would have been supplied on 215/50R17 95W
    As an estate it MUST have XL rated tyres
    The alternative is 225/45R17 94W, which is what most people swap to
    If it still has the Good Year NCT5 then check the country of manufacture, if German then OK, anything then advise the salesperson they need to be replaced and check recalls
    Front tyres last about 20K miles, when swapped rear to front as they wear
    You can get a set of rear tyres to last 50K miles, but they will suffer from tramlining and all the associated problems with that (hence the advice, swap rear to front as they wear) due to the chassis design
    Regular Member signum03's Avatar
    worthing
    i have a signum 3.0 v6 cdti and love it, plenty of power and as mentioned bomb proof(touched wood!) milegage on mine is 106,000 and still drives like a new car, they are rare though!
    Regular Member m3ath3ad's Avatar
    Aug 2007
    Minehead
    firstly welcome along!! i have a 3.0 cdti manual sri on 05 preface lift just gone over 40.000 miles and it drives a dream lovely car, great for long drives to they do like the juice only if you like put your foot down!!!
    south wales
    hope there more popular than a 2.0t as there is 1 listed and that is sold,im begining to think i may have to settle on another engine but dont want another 2.2 and the 3.2 is to big
    Regular Member Swaite53's Avatar
    South Wales
    The 2.0T is a good engine, if you're open to suggestions or you're struggling to find the car you want as a 3.0CDTi.
    In my opinion, is by far the best Vectra-C engine overall. Seems to have fewer problems than some others, more than enough power as standard, but is very tuneable for those wanting more. Fuel economy is close to the 2.2 (petrol), but obviously is not good compared to the diesels.
  1. Thinking about buying insignia elite
    By wayne10244 in forum Insignia car chat
    Last Post: 18th May 2012, 20:12
  2. Thinking about buying a Vectra Estate
    By frenchman in forum Vectra C / Signum Car Chat
    Last Post: 22nd October 2009, 11:26
  3. 3.0 CDTi auto estate ELITE
    By JonV6 in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 9th August 2008, 18:16
  4. 2004 V6 Cdti Elite Estate Auto
    By nellsey in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 22nd July 2008, 01:17
  5. Thinking of Buying Elite CDTI
    By doncaster_mainline in forum Vectra C / Signum Car Chat
    Last Post: 12th June 2007, 20:09
