Results 1 to 10 of 11
Thread: Tyres
    Regular Member Damian's Avatar
    Market Drayton
    Default Tyres
    I currently have 225/45 R18 95Y on my car. 05 Sri Vec.
    These are quite expensive to change, can another size be put on which may be cheaper
    [Ex]Admin Duncan's Avatar
    Is that size right? 225/15/18.
    Market Drayton
    Ooops edited now
    Aah, that's better! lol
    I can't see any other size of 18 listed in the VX manual - just the 225/45's. But I'm sure somebody else will have fitted a different size.......
    you can try 235/40 18 although i actually use 225/40 18 which is actually closer to the orginal 17" diameter than the vauxhall tyre 225/45 18, which is bizare. Loads more options for tyre choice too.
    tyre options work out like this
    17" sri alloy 215/50 17 = 647mm dia
    18" factory 225/45 18 = 660mm dia
    225/40 18 aftermarket = 637mm dia
    235/40 18 aftermarket = 669mm dia
    Maybe the gearing is tech2 set for the factory 18's? in which case the 235/40 might be an option. Going from factory 17s to 18's, the 225/40 18 looks the nearest choice.
    There you go Damian. I knew sombody would be along!
    Market Drayton
    Quote Originally Posted by Andy
    I have factory 18's fitted, so 235/40 18 would be better for me. Are they likely to be cheaper than the 225/45 18 ?
    ive got 225/40/18
    got some kumo's from stoke on trent for £120 a pair
    Full Member chunkster's Avatar
    North east HQ
    ive got 225/40/18 on mine, they came withthe wheels but upon looking them up they are about £65 inc delivery to you. mine are Nankang NS2, not one i would choose but they get a very good write up and i have no complaints about mine after 2 months of driving on them
    Wayne -
  3. More tyres....!
