Thread: intermitent dash failure
    Jun 2007
    peterhead
    Default intermitent dash failure
    i have a 1.8ls on a 52 plate,my problem is quite a strange one.every so often as im driving along all the lights within my speedo cluster come on then the whole thing shuts down,speedo etc too,now the really strange part,if you slow down to a crawl with the clutch pressed and open and close the drivers door nine times out of 10 they come back on again!!! otherwise they please themselves when they come on again,whether the ignitions been turned off or not,hopefully i can get this fixed without a vauxhall garage and a nasty bill being involved,cheers.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Hi mate, its more than likely 1 of 2 things. The ABS plug, free to clean, or the CIM module, £350+ dealer fix. With mine, I just sprayed the ABS plug contacts with WD40 and all has been fine for the last couple of years.
    Regular Member Yetti's Avatar
    mine does this too, also comes back on if you turn on hazzard lights for a moment, but not always
    just going to put up with it till it crashes (not literally) haha
    Surrey
    Try cleaning the contacts of the instrument cluster, plug is on the back right.
  1. Dash Board headlight bulb failure
    By srobertson1 in forum Vectra C / Signum Car Chat
    Last Post: 18th July 2012, 21:34
  2. Bulb failure light on dash - always on.
    By Dal5band in forum Bodywork & Interior
    Last Post: 15th December 2011, 14:23
  3. Bulb Failure in Dash
    By TheVoid in forum Electrical & ICE (including SatNav)
    Last Post: 10th May 2011, 15:50
  4. bulb failure warning light on dash
    By bigbill94 in forum Electrical & ICE (including SatNav)
    Last Post: 9th June 2010, 19:35
