Thread: Rear Fog Light
    Regular Member Ben H's Avatar
    Herts\Beds Border
    Default Rear Fog Light
    JUst read on another forum about the mk5 Astra only having one rear foglight & modding it to have a second the other side & someone mentioned they know the Vec C only has one fog light.
    I've never given it a thought & can't be bothered to go & look but is this true???
    Poxy tight arssed Vox
    Mind you saying that I know BMW started this on the E46 a while ago.
    Regular Member Damian's Avatar
    Market Drayton
    Tis true.
    There is the arguement that a car should only have 1 fog light so not to be confused with the brake lights whilst driving in foggy conditions.
    I believe you can run a wire between your lights and get the other fog light to work.
    I also believe that is a brake light fails, one of the other lights is used instead (I think I read this somewhere, maybe I dreamt it)
    Regular Member MalcGSI's Avatar
    E Sussex & Kent
    Quote Originally Posted by Damian
    Tis true.
    Obviously on mine the other light failed as well then.
    Yep, you're right Ben. The Vec has just the one foglight. It's not them being tight, it's a EU thingy about safety. To distinguish, as said above, between brake and fog lights.
    You can stick a wire from the other side to light it up, but why bother? I 'think' if you do that you also mess up the bulb failure warning, and possibly the other feature mentioned i.e. a different bulb coming on if a brake light fails (you weren't dreaming it Damian! lol)
    South East
    brake light failure and another bulb takes over is well cool as mine did the.
    Regular Member dezzie's Avatar
    May 2006
    blackpool
    so is there a "bulb out" warning feature on 2.2 sri then??
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Yes, should be. Not all bulbs are covered though
    Herts\Beds Border
    Tight fisted. Ah well, not like it ever gets driven when it's gonna be an issue.
    Don't know about this EU thingy though, couldn't really care, if they can see my fog lights they can see me.
    E Sussex & Kent
    Quote Originally Posted by vectrasri03
    Where's the bulb that takes over, as I obviously need to check this out.
    South East
    All the bulbs in the back are 21W. The car pulses the volts to generate the correct brightness for the tail light, therefore it can control this bulb to make it a brake light. It could in fact make any of the bulbs do what it wants but colour of bulbs and the lens colour limits this.
    My SRI tells you when a bulb is out with a nice picture using the colour display. Once you clear the display warning a reminder light is displayed on the lcd in the speedo area.
  1. random mod, anyone converted the rear ashtray to light up the rear?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2013, 02:21
  2. Rear pad light?
    By frasedeb in forum Handling & Braking
    Last Post: 8th February 2010, 16:30
  3. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
