Thread: warning lights on
    Jun 2009
    WARWICKSHIRE
    Default warning lights on
    got into my car today and noticed that my abs and a orange triangle with a car skiding is staying on anyone know what this means ,,, checked brake fluid ..full ,,,,TIA john
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Sounds like you have an ABS malfuction (could be as simple as a dirty wheel sensor) Get the car hooked up to diagnostics asap
    Jun 2009
    WARWICKSHIRE
    i have just noticed my antilock brake do not work either
    newcastle upon tyne
    check the abs harness is pluged in properly. the harness clips onto the strut.
    Given the ABS and TC light are on together it sounds like the module has failed
    Even with the ABS sensor not fitted correctly, you don't normally get a warning for that
    Jun 2009
    WARWICKSHIRE
    Given the ABS and TC light are on together it sounds like the module has failed......what does that mean what do i need to do i dont know anything about brakes at all
    Be aware you will NOT have either ABS or TC, so drive accordingly until inspected and diagnosed by a mechanic
    Equally, this is a MoT failure point, so remember that in the VERY unlikely event your car is inspected at the roadside it could be issued with a prohibition notice
    Jun 2009
    WARWICKSHIRE
    took me car to martin rumble and they put it on the machine and they have told me i need a new front bearing hub thing...£169 thats not to bad
    Jun 2009
    WARWICKSHIRE
    the sensor in the bearing had gone or something
  1. ABS and ESP warning lights
    By ChristopheCDTI in forum Suspension, Wheels & Brakes
    Last Post: 4th October 2011, 17:13
  2. warning lights
    By ben2996 in forum Troubleshooting
    Last Post: 31st January 2011, 17:09
  3. warning lights
    By jules in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2009, 22:09
  4. warning lights
    By lee_car in forum Troubleshooting
    Last Post: 30th October 2008, 14:01
  5. warning lights
    By blackbeauty in forum Electrical & ICE (including SatNav)
    Last Post: 14th June 2008, 21:20
