Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: Slow 2.2
    Unhappy Slow 2.2
    Can anyone help with a problem i am having with my 03 2.2 sxi
    I have noticed that the top end accelaration is very flat and gutless.
    It feels like a 1.2 corsa not a 2.2 vectra.
    I fitted a K&N panel filter and new plugs[DENSO ITV 16] Which made it a lot
    smoother by the way.
    The car has only done 28.000 miles.
    Ihave checked that the brakes all free and all is fine.
    Any ideas would be most welcome.
    Thanks.
    Superbird.
    take the panel filter off, refit the orginal plugs, make sure they are gapped correctly and see if its any better.
    the 2.2 isnt slow, but its not going to leave smoking tyre marks at the traffic lights either. Is it really slow or are you looking at the speedo? How long would you guess, very roughly its taking you to get to 60?
    Regular Member The Doc's Avatar
    'Norf Yorks.
    Get it to somewhere to check the MAF sensor is reading in range too and your lambdas.
    Plugs must be gapped correctly. Are those the right spec'd plugs for you engines? If you don't have a healthy spark, then it won't rev.
    Default Re Slow 2.2
    Thanks for the reply.
    Denso are the only iridium plugs i could get for this engine.
    Ngk do not list a part number.
    I did try with the old plugs back in but it was just the same.
    The car starts fine.
    Its when im sitting at between 50-70 and changing down to overtake it
    feels like its lacking some oomph.
    I have timed 50-70 in 3rd and it takes between 7-8 secs.
    I dread to think what the 1.8 must be like?.
    Another thing i would like to mention.
    I read alot in all the forums that some lads take the air filtter cover off
    and inside there is a pipe that sticks out about 2 and a halfe inches.
    And to cut this off as it improves air flow!
    I wished i had left it alone now.
    However once i get round to it ill get it checked out.
    Thanks again.
    Superbird.
    Default 0-60
    Hello Andy.
    I would say the 0-60 takes about 10-11 secs.
    And i always use shell optimax aswell.
    Thanks.
    Superbird.
    'Norf Yorks.
    I would get the above sensors checked. Sounds like there could be an air leak or poor airflow.
    Default Re slow 2.2
    Hello again.
    When my wife lets me get hold of the car i will get those
    sensors checked.
    The Denso Iridium plugs i would recomend as the car is a lot smoother.
    Funny thing is i put the standard air filter back in and it seemed to pull
    a bt better?
    Superbird.
    Regular Member Merick's Avatar
    Mar 2007
    Wigan & Preston
    Did you manage to find the problem with this? I've took the tube off my lower box and waiting for a K&N filter to arrive.. wondering if i should have bothered now !!! lol
    Default Slow 2.2
    Hi.
    All that i have done to my 2.2 is
    As you have done removed the bottom tube in the air box
    and cut back the top tube in the airbox lid and fitted a set of Denso ITV16
    sparkplugs plus a k&n fillter.
    All this improves the bottom end pickup.
    And another thing tht helps is shell v-power fuel.
    But i still lack's top end grunt that an engine this size should have.
    Perhaps a catback system or a ecu reprogram would help?
    And that is more cash!
    Hope this helps.
    Regards.
    Superbirdsxi
    Mar 2007
    Wigan & Preston
    I was testing mine last night (only have the bottom tube removed so far) and i was going from 70 to 80 in about 2.5 seconds in 4th. Haven't had chance to test 0-60 yet.. Too many coppers around here and all of our straight roads are 30 roads! I have noticed that the car performs much better just after refuelling... surely this makes the car heavier therefore shouldn't be any faster?? lol
    I use v-power most of the time.. if not, then it's tesco's fuel for the clubcard points! lol
    I'm glad you mentioned sparks.... where are they on the Vectra C? I can't see em anywhere. We could only find 3 on the Vectra B 2.5 V6. Anyone got any pictures? (of the veccy c, that is)?
  1. Slow to pull away - dangerously slow to pull away (150cdti auto)
    By the1theycallthe1 in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2012, 21:10
  2. Is LMF always this slow?
    By Celes in forum Vectra C / Signum Car Chat
    Last Post: 24th December 2010, 11:22
  3. very slow warming up
    By IA76 in forum Engine & Drivetrain
    Last Post: 28th April 2010, 19:27
  4. why does it go slow
    By dizzyblonde in forum Engine & Drivetrain
    Last Post: 19th May 2009, 21:13
  5. Slow down !!!!
    By richardg3.2 in forum General Chat
    Last Post: 13th May 2006, 19:18
